[petsc-dev] Is this a bug in test generation?
    Stefano Zampini
    stefano.zampini at gmail.com
    Fri Aug 20 05:43:02 CDT 2021
Scott
This test is specified as
   testset:
      suffix: expl
      nsize: {{1 2}}
      filter: grep -v "MPI processes" | grep -v " type:" | grep -v "Mat Object"
      args: -ksp_converged_reason -view_explicit_mat -pc_type none -ksp_type {{cg gmres}}
      test:
        args: -mat_type aij
      test:
        requires: hypre
        args: -mat_type hypre
It triggers an error here https://gitlab.com/petsc/petsc/-/jobs/1519558357 <https://gitlab.com/petsc/petsc/-/jobs/1519558357>, with a  CI configuration without hypre.
Other testset instances works fine if any “require:" is both specified in the testset body and in the specific test.
Is this supposed to work?
Thanks
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210820/e143a4d7/attachment.html>
