[petsc-dev] building on Spock
    Mark Adams
    mfadams at lbl.gov
    Fri Aug 13 13:41:24 CDT 2021
On Fri, Aug 13, 2021 at 2:25 PM Aaron Scheinberg <aaron at jubileedev.com>
wrote:
> Hey Mark, I believe the problem is in this line:
> export PE_MPICH_GTL_DIR_amd_gfx908="-L/opt/cray/pe/mpich/8.1.4/gtl/lib"
> "8.1.4" should be replaced with "default" since I think that version is in
> flux.
Good catch.
Its running  now.
> On Fri, Aug 13, 2021 at 1:49 PM Mark Adams <mfadams at lbl.gov> wrote:
>> I was building on Spock a few weeks ago, but am getting these errors now.
>> I have a setup with this environment and get this error.
>> Any ideas?
>> Thanks,
>> Mark
>>     module load craype-accel-amd-gfx908
>>     module load rocm
>>     module load emacs
>>     module load zlib
>>     module load autoconf automake libtool
>>     ## These must be set before compiling so the executable picks up GTL
>>     export
>>     export PE_MPICH_GTL_LIBS_amd_gfx908="-lmpi_gtl_hsa"
>>     ## These must be set before running
>>     export MPIR_CVAR_GPU_EAGER_DEVICE_MEM=0
>>     export MPICH_GPU_SUPPORT_ENABLED=1
>>     export MPICH_SMP_SINGLE_COPY_MODE=CMA
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210813/1a760530/attachment.html>
