[petsc-dev] how do people manage projects that require two or more PETSc branches
Matthew Knepley
knepley at gmail.com
Sun Apr 18 08:58:52 CDT 2021
On Sat, Apr 17, 2021 at 7:38 PM Jed Brown <jed at jedbrown.org> wrote:
> One option is to work on the throw-away combined branch as above, keep
> your commits for the two topics distinct, then cherry-pick out into the
> separate topic branches.
> If you are committing in the topics and respinning the throw-away branch,
> I would recommend rerere, so you don't have to repeat conflict resolution.
> https://git-scm.com/docs/git-rerere
This is what happens for PyLith. I work on a few topic branches that are
all needed. I keep a branch, knepley/pylith, to hold all of this. In my
work branches,
I just pile the commits in until everything is working. That way merges are
knepley/pylith are fast-forward. Then when these branches pass the CI and
are
ready to be merged to PETSc, I rebase them and make nice commits, then
recreate knepley/pylith. That means everyone else in the project has to
destroy
the old knepley/pylith and get a new one, which is annoying, but I do not
see a better way.
It might be nice if git had an ephemeral branch feature, where you could
say that some branch is the combination of a few others and every
time they change, it changes too.
Matt
> On Sat, Apr 17, 2021, at 5:02 PM, Jacob Faibussowitsch wrote:
> I have done this maybe only a handful of times (and not with petsc) but
> take a look at git worktree https://git-scm.com/docs/git-worktree
> The basics of it is:
> 1. cd $PETSC_DIR — or wherever the root folder of your repo of choice is
> 2. git worktree add ../myBranchName
> Then this recreates the entire src tree of the current branch in a
> separate directory (namely $PETSC_DIR/../myBranchName). Not sure how useful
> it is for petsc, given how dependent everything is on $PETSC_DIR but it's
> occasionally useful. Its as if you had 2 separate clones of petsc, but they
> both share the same .git folder (I think).
> Best regards,
> (Jacob Fai - booss - oh - vitch)
> On Apr 17, 2021, at 17:24, Barry Smith <bsmith at petsc.dev> wrote:
> Say I have a project (a code whose source is not in the PETSc
> repository) that requires code from two PETSc branches (that may or may not
> yet be MR) but I do not want to make a single PETSc branch (since it would
> be incoherent). I may possibly be needing to add code to both of the PETSc
> branches as I develop the project. I also need to do development sometimes
> on different machines.
> I can do
> git checkout branch1
> git checkout -b combinedbranch
> git merge branch2
> configure
> make
> use for a while
> but now I need to fix or add something to branch1 (which, of course, will
> be an iterative process as I write the code and fix it) and then add
> something in branch2.
> Doing the above procedure over and over again is tedious and prone to
> produce errors, editing in the wrong branch etc.
> Does anyone have advice on good work flows for this situation?
> Barry
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210418/2aadadf4/attachment-0001.html>
