[petsc-dev] p4est w/o MPI
    Matthew Knepley
    knepley at gmail.com
    Fri Apr 16 14:55:01 CDT 2021
On Fri, Apr 16, 2021 at 2:06 PM Satish Balay via petsc-dev <
petsc-dev at mcs.anl.gov> wrote:
> Sure that might work. Also just commenting out the 3 lines for that check
> got the build going for me.
> Or a simple change (but a bit intrusive):
> [balay at pj01 petsc]$ diff -Nru ./arch-linux-c-debug/include/sc.h~
> --- ./arch-linux-c-debug/include/sc.h~  2021-04-16 12:59:20.803995227 -0500
> +++ ./arch-linux-c-debug/include/sc.h   2021-04-16 13:00:06.490993496 -0500
> @@ -83,7 +83,7 @@
>  #ifdef SC_ENABLE_MPI
>  #include <mpi.h>
>  #else
> -#ifdef MPI_SUCCESS
> +#if defined(MPI_SUCCESS) && !defined(MPIUNI_H)
>  #error "mpi.h is included.  Use --enable-mpi."
>  #endif
>  #endif
> Also getting test suite errors - Matt might have to check on. [attaching
> log]
Hmm, this looks like an MPIUNI memory leak with split collectives. I will
have to spin up that configuration and track it down.
   Matt
> Satish
> On Fri, 16 Apr 2021, Isaac, Tobin G wrote:
> > Hmm.  So if petsc always compiles mpiuni if --with-mpi=0, then it makes
> me think it should be possible to drop requires(MPI) from p4est, while
> still passing `--enable-mpi` to p4est.
> > Maybe: if mpiuni doesn't provide some esoteric part of MPI that p4est
> uses, it will break.
> > Toby Isaac, Assistant Professor, GTCSE
> > ________________________________
> > From: Satish Balay <balay at mcs.anl.gov>
> > Sent: Friday, April 16, 2021 1:03:55 PM
> > To: Isaac, Tobin G <tisaac at cc.gatech.edu>
> > Cc: petsc-dev <petsc-dev at mcs.anl.gov>
> > Subject: Re: [petsc-dev] p4est w/o MPI
> > Thanks! Another issue:
> > mpiuni provides mpi.h. And I get the following errors when building
> PETSc.
> > /home/balay/petsc/arch-linux-c-debug/include/sc.h:87:2: error: #error
> >    87 | #error "mpi.h is included.  Use --enable-mpi."
> > etc..
> > Satish
> > > Yes, `--disable-mpi` should be accepted by p4est.
> > > ________________________________________
> > > Sent: Friday, April 16, 2021 11:47
> > > To: Satish Balay via petsc-dev
> > > Cc: Isaac, Tobin G
> > > BTW: Is there no --disable-mpi option?
> > > Satish
> > > On Fri, 16 Apr 2021, Satish Balay via petsc-dev wrote:
> > > > MPI pacakge is a bit weird compared to others [as it does this funny
> thing with MPIUNI].
> > > > For regular packages - I guess I would use 'if package.found'
> > > > I guess I should create an MR with this diff.
> > > > Satish
> > > > diff --git a/config/BuildSystem/config/packages/p4est.py
> b/config/BuildSystem/config/packages/p4est.py
> > > > index e7108b0ab8..40d6797f02 100644
> > > > --- a/config/BuildSystem/config/packages/p4est.py
> > > > +++ b/config/BuildSystem/config/packages/p4est.py
> > > > @@ -24,14 +24,16 @@ class Configure(config.package.GNUPackage):
> > > >      self.blasLapack =
> framework.require('config.packages.BlasLapack',self)
> > > >      self.zlib       = framework.require('config.packages.zlib',self)
> > > >      self.memalign   = framework.argDB['with-memalign']
> > > > -    self.deps       = [self.mpi,self.blasLapack,self.zlib]
> > > > +    self.deps       = [self.blasLapack,self.zlib]
> > > > +    self.odeps      = [self.mpi]
> > > >      return
> > > >    def formGNUConfigureArgs(self):
> > > >      args = config.package.GNUPackage.formGNUConfigureArgs(self)
> > > >      if self.argDB['with-p4est-debugging']:
> > > >        args.append('--enable-debug')
> > > > -    args.append('--enable-mpi')
> > > > +    if not self.mpi.usingMPIUni:
> > > > +      args.append('--enable-mpi')
> args.append('CPPFLAGS="'+self.headers.toStringNoDupes(self.dinclude)+'"')
> > > >      args.append('LIBS="'+self.libraries.toString(self.dlib)+'"')
> > > >      args.append('--enable-memalign='+self.memalign)
> > > > > Matt, this is the configure logic I would like, but I don't know
> how to do it:
> > > > > - configure p4est after MPI, but do not require MPI
> > > > > - if MPI is present, add the '--enable-mpi' flack in
> formGNUConfigureArgs(), otherwise omit it.
> > > > > From: Isaac, Tobin G <tisaac at cc.gatech.edu>
> > > > > Sent: Friday, April 16, 2021 11:03
> > > > > To: Mark Adams; For users of the development version of PETSc
> > > > > p4est has a mode where it can compile without MPI, I don't know if
> PETSc is using it, will check.
> > > > > From: petsc-dev <petsc-dev-bounces at mcs.anl.gov> on behalf of Mark
> Adams <mfadams at lbl.gov>
> > > > > Sent: Friday, April 16, 2021 10:23
> > > > > To: For users of the development version of PETSc
> > > > > Subject: [petsc-dev] p4est w/o MPI
> > > > > I don't have MPI (Fugaku w/ gcc) and p4est seems to need it. Is
> there a work around?
> > > > > Thanks,
> > > > > Mark
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210416/bc088e62/attachment-0001.html>
