[petsc-dev] p4est w/o MPI
    Isaac, Tobin G
    tisaac at cc.gatech.edu
    Fri Apr 16 12:53:11 CDT 2021
Hmm.  So if petsc always compiles mpiuni if --with-mpi=0, then it makes me think it should be possible to drop requires(MPI) from p4est, while still passing `--enable-mpi` to p4est.
Maybe: if mpiuni doesn't provide some esoteric part of MPI that p4est uses, it will break.
Toby Isaac, Assistant Professor, GTCSE
Sent: Friday, April 16, 2021 1:03:55 PM
To: Isaac, Tobin G <tisaac at cc.gatech.edu>
Cc: petsc-dev <petsc-dev at mcs.anl.gov>
Subject: Re: [petsc-dev] p4est w/o MPI
Thanks! Another issue:
mpiuni provides mpi.h. And I get the following errors when building PETSc.
/home/balay/petsc/arch-linux-c-debug/include/sc.h:87:2: error: #error "mpi.h is included.  Use --enable-mpi."
   87 | #error "mpi.h is included.  Use --enable-mpi."
etc..
Satish
On Fri, 16 Apr 2021, Isaac, Tobin G wrote:
> Yes, `--disable-mpi` should be accepted by p4est.
> From: Satish Balay <balay at mcs.anl.gov>
> Sent: Friday, April 16, 2021 11:47
> To: Satish Balay via petsc-dev
> Cc: Isaac, Tobin G
> BTW: Is there no --disable-mpi option?
> Satish
> On Fri, 16 Apr 2021, Satish Balay via petsc-dev wrote:
> > MPI pacakge is a bit weird compared to others [as it does this funny thing with MPIUNI].
> > For regular packages - I guess I would use 'if package.found'
> > I guess I should create an MR with this diff.
> > Satish
> > diff --git a/config/BuildSystem/config/packages/p4est.py b/config/BuildSystem/config/packages/p4est.py
> > index e7108b0ab8..40d6797f02 100644
> > --- a/config/BuildSystem/config/packages/p4est.py
> > +++ b/config/BuildSystem/config/packages/p4est.py
> > @@ -24,14 +24,16 @@ class Configure(config.package.GNUPackage):
> >      self.blasLapack = framework.require('config.packages.BlasLapack',self)
> >      self.zlib       = framework.require('config.packages.zlib',self)
> >      self.memalign   = framework.argDB['with-memalign']
> > -    self.deps       = [self.mpi,self.blasLapack,self.zlib]
> > +    self.deps       = [self.blasLapack,self.zlib]
> > +    self.odeps      = [self.mpi]
> >      return
> >    def formGNUConfigureArgs(self):
> >      args = config.package.GNUPackage.formGNUConfigureArgs(self)
> >      if self.argDB['with-p4est-debugging']:
> >        args.append('--enable-debug')
> > -    args.append('--enable-mpi')
> > +    if not self.mpi.usingMPIUni:
> > +      args.append('--enable-mpi')
> >      args.append('CPPFLAGS="'+self.headers.toStringNoDupes(self.dinclude)+'"')
> >      args.append('LIBS="'+self.libraries.toString(self.dlib)+'"')
> >      args.append('--enable-memalign='+self.memalign)
> > > Matt, this is the configure logic I would like, but I don't know how to do it:
> > > - configure p4est after MPI, but do not require MPI
> > > - if MPI is present, add the '--enable-mpi' flack in formGNUConfigureArgs(), otherwise omit it.
> > > From: Isaac, Tobin G <tisaac at cc.gatech.edu>
> > > Sent: Friday, April 16, 2021 11:03
> > > To: Mark Adams; For users of the development version of PETSc
> > > p4est has a mode where it can compile without MPI, I don't know if PETSc is using it, will check.
> > > From: petsc-dev <petsc-dev-bounces at mcs.anl.gov> on behalf of Mark Adams <mfadams at lbl.gov>
> > > Sent: Friday, April 16, 2021 10:23
> > > To: For users of the development version of PETSc
> > > Subject: [petsc-dev] p4est w/o MPI
> > > I don't have MPI (Fugaku w/ gcc) and p4est seems to need it. Is there a work around?
> > > Thanks,
> > > Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210416/bfe9ced5/attachment.html>
