[petsc-dev] p4est w/o MPI
Matthew Knepley
knepley at gmail.com
Fri Apr 16 11:22:39 CDT 2021
On Fri, Apr 16, 2021 at 11:25 AM Isaac, Tobin G <tisaac at cc.gatech.edu>
wrote:
> Matt, this is the configure logic I would like, but I don't know how to do
> it:
> - configure p4est after MPI, but do not require MPI
> - if MPI is present, add the '--enable-mpi' flack in
> formGNUConfigureArgs(), otherwise omit it.
I think I can fix it today.
Matt
> From: Isaac, Tobin G <tisaac at cc.gatech.edu>
> Sent: Friday, April 16, 2021 11:03
> To: Mark Adams; For users of the development version of PETSc
> Subject: Re: [petsc-dev] p4est w/o MPI
> p4est has a mode where it can compile without MPI, I don't know if PETSc
> is using it, will check.
> From: petsc-dev <petsc-dev-bounces at mcs.anl.gov> on behalf of Mark Adams <
> mfadams at lbl.gov>
> Sent: Friday, April 16, 2021 10:23
> To: For users of the development version of PETSc
> Subject: [petsc-dev] p4est w/o MPI
> I don't have MPI (Fugaku w/ gcc) and p4est seems to need it. Is there a
> work around?
> Thanks,
> Mark
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210416/ac62d4ee/attachment-0001.html>
