[petsc-dev] p4est w/o MPI
    Mark Adams
    mfadams at lbl.gov
    Fri Apr 16 10:45:23 CDT 2021
On Fri, Apr 16, 2021 at 11:33 AM Satish Balay <balay at mcs.anl.gov> wrote:
> Mark, Why a no-mpi build on Fugaku?
Kokkos Kernels + OMP barfed and Kokkos suggested gcc. There does not seem
to be an MPI for GCC here.
> Toby - there is one more issue with p4est - build error when using
> --with-batch=1
> Attaching configure.log
> Satish
> On Fri, 16 Apr 2021, Isaac, Tobin G wrote:
> > p4est has a mode where it can compile without MPI, I don't know if PETSc
> is using it, will check.
> > ________________________________________
> > From: petsc-dev <petsc-dev-bounces at mcs.anl.gov> on behalf of Mark Adams
> <mfadams at lbl.gov>
> > Sent: Friday, April 16, 2021 10:23
> > To: For users of the development version of PETSc
> > Subject: [petsc-dev] p4est w/o MPI
> > I don't have MPI (Fugaku w/ gcc) and p4est seems to need it. Is there a
> work around?
> > Thanks,
> > Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210416/7301f852/attachment.html>
