[petsc-dev] p4est w/o MPI
    Isaac, Tobin G
    tisaac at cc.gatech.edu
    Fri Apr 16 10:11:41 CDT 2021
Matt, this is the configure logic I would like, but I don't know how to do it:
- configure p4est after MPI, but do not require MPI
- if MPI is present, add the '--enable-mpi' flack in formGNUConfigureArgs(), otherwise omit it.
Sent: Friday, April 16, 2021 11:03
To: Mark Adams; For users of the development version of PETSc
Subject: Re: [petsc-dev] p4est w/o MPI
p4est has a mode where it can compile without MPI, I don't know if PETSc is using it, will check.
From: petsc-dev <petsc-dev-bounces at mcs.anl.gov> on behalf of Mark Adams <mfadams at lbl.gov>
Sent: Friday, April 16, 2021 10:23
To: For users of the development version of PETSc
Subject: [petsc-dev] p4est w/o MPI
I don't have MPI (Fugaku w/ gcc) and p4est seems to need it. Is there a work around?
