[petsc-dev] Error on Fugaku
Wed Apr 14 14:34:27 CDT 2021
Additional kokkos cmake arguments can be passed in via --download-kokkos-cmake-arguments=string option.
Satish
On Wed, 14 Apr 2021, Mark Adams wrote:
> Satish,
> For the fujitsu compiler OMP is -Kopenmp.
> Sarat (cc'ed) tells me that he built Kokkos with:
> cmake -DCMAKE_BUILD_TYPE=Release \
>     -DCMAKE_INSTALL_PREFIX=${KOKKOS_SRC_DIR}/install \
>     -DBUILD_TESTING=OFF \
>     -DKokkos_ENABLE_LIBDL=OFF \
>     -DKokkos_ENABLE_OPENMP=ON \
>     -DKokkos_ENABLE_SERIAL=ON \
>     -DKokkos_ENABLE_AGGRESSIVE_VECTORIZATION=ON \
> How might I make this happen in PETSc?
> Thanks,
> Mark
> > > I have this building now.
> > > Do you know anything about OpenMP?
> > > I can add --with-openmp
> > > That should get Kokkos to be made with OpenMP.
> > > Should PETSc deal with the compilers correctly?
> > Well it tries the following compiler options for openmp.
> >     oflags = ["-fopenmp", # Gnu
> >               "-qsmp=omp",# IBM XL C/C++
> >               "-h omp",   # Cray. Must come after XL because XL interprets
> > this option as meaning "-soname omp"
> >               "-mp",      # Portland Group
> >               "-Qopenmp", # Intel windows
> >               "-openmp",  # Intel
> >               "-xopenmp", # Sun
> >               "+Oopenmp", # HP
> >               "/openmp"   # Microsoft Visual Studio
> > I don't know what the flag for fugaku compiler is.
> > Satish
> > > Thanks,
> > > Mark
> > > On Wed, Apr 14, 2021 at 1:45 PM Mark Adams <mfadams at lbl.gov> wrote:
> > > > Thanks,
> > > > If you feel inspired you could try Kokkos :||
> > > > I am in a parking lot waiting for my daughter but can try this when I
> > get
> > > > home,
> > > > Thanks again,
> > > > Mark
> > > > On Wed, Apr 14, 2021 at 1:33 PM Satish Balay <balay at mcs.anl.gov>
> > wrote:
> > > >> I think I allocated a single node - and did the build on it.
> > > >> Now I'm getting an error - don't know what changed..
> > > >> login6$ pjsub --interact -L "node=1" -L "rscunit=rscunit_ft01" -L
> > > >> "rscgrp=eap-int" -L "elapse=1:00:00" --sparam "wait-time=600"
> > > >> [ERR.] PJM 0059 pjsub rscgrp=eap-int is disabled.
> > > >> Ok - the following worked..
> > > >> [INFO] PJM 0000 pjsub Job 6301572 submitted.
> > > >> [INFO] PJM 0081 .connected.
> > > >> [INFO] PJM 0082 pjsub Interactive job 6301572 started.
> > > >> [a04201 at j31-3110s petsc]$
> > > >> Ok - trying this build now.
> > > >> [a04201 at j31-3110s petsc]$ cat
> > > >> ~/petsc.save/arch-arm/lib/petsc/conf/reconfigure-arch-arm.py
> > > >> #!/usr/bin/python3
> > > >> if __name__ == '__main__':
> > > >>   import sys
> > > >>   import os
> > > >>   sys.path.insert(0, os.path.abspath('config'))
> > > >>   import configure
> > > >>   configure_options = [
> > > >>     '--with-blaslapack-lib=-lfjlapack',
> > > >>     '--with-debugging=0',
> > > >>     'CC=mpifcc',
> > > >>     'CXX=mpiFCC',
> > > >>     'FC=mpifrt',
> > > >>     'PETSC_ARCH=arch-arm',
> > > >>   configure.petsc_configure(configure_options)
> > > >> --download-p4est --download-zlib
> > > >> <snip>
> > > >> p4est:
> > > >>   Includes: -I/vol0004/ra010009/a04201/petsc/arch-arm/include
> > > >>   Library:  -Wl,-rpath,/vol0004/ra010009/a04201/petsc/arch-arm/lib
> > > >> -L/vol0004/ra010009/a04201/petsc/arch-arm/lib -lp4est -lsc
> > > >> Ok - this worked for me.
> > > >> Satish
> > > >> > Do you recall what nodes you use to build on a "compute" node, to
> > avoid
> > > >> > cross compilation?
> > > >> > On Wed, Apr 14, 2021 at 12:08 PM Satish Balay <balay at mcs.anl.gov>
> > > >> wrote:
> > > >> > > looks like p4est cannot be cross-compiled.
> > > >> > > Satish
> > > >> > > > I get this error with p4est on Fugaku.
> > > >> > > > It is a Fortran error. Odd.
> > > >> > > > Mark
