[petsc-dev] Error on Fugaku
Satish Balay
balay at mcs.anl.gov
Wed Apr 14 13:44:31 CDT 2021
On Wed, 14 Apr 2021, Mark Adams wrote:
> I have this building now.
> Do you know anything about OpenMP?
> I can add --with-openmp
> That should get Kokkos to be made with OpenMP.
> Should PETSc deal with the compilers correctly?
Well it tries the following compiler options for openmp.
oflags = ["-fopenmp", # Gnu
"-qsmp=omp",# IBM XL C/C++
"-h omp", # Cray. Must come after XL because XL interprets this option as meaning "-soname omp"
"-mp", # Portland Group
"-Qopenmp", # Intel windows
"-openmp", # Intel
"-xopenmp", # Sun
"+Oopenmp", # HP
"/openmp" # Microsoft Visual Studio
I don't know what the flag for fugaku compiler is.
Satish
> Thanks,
> Mark
> On Wed, Apr 14, 2021 at 1:45 PM Mark Adams <mfadams at lbl.gov> wrote:
> > Thanks,
> > If you feel inspired you could try Kokkos :||
> > I am in a parking lot waiting for my daughter but can try this when I get
> > home,
> > Thanks again,
> > Mark
> > On Wed, Apr 14, 2021 at 1:33 PM Satish Balay <balay at mcs.anl.gov> wrote:
> >> I think I allocated a single node - and did the build on it.
> >> Now I'm getting an error - don't know what changed..
> >> login6$ pjsub --interact -L "node=1" -L "rscunit=rscunit_ft01" -L
> >> "rscgrp=eap-int" -L "elapse=1:00:00" --sparam "wait-time=600"
> >> [ERR.] PJM 0059 pjsub rscgrp=eap-int is disabled.
> >> Ok - the following worked..
> >> [INFO] PJM 0000 pjsub Job 6301572 submitted.
> >> [INFO] PJM 0081 .connected.
> >> [INFO] PJM 0082 pjsub Interactive job 6301572 started.
> >> [a04201 at j31-3110s petsc]$
> >> Ok - trying this build now.
> >> [a04201 at j31-3110s petsc]$ cat
> >> ~/petsc.save/arch-arm/lib/petsc/conf/reconfigure-arch-arm.py
> >> #!/usr/bin/python3
> >> if __name__ == '__main__':
> >> import sys
> >> import os
> >> sys.path.insert(0, os.path.abspath('config'))
> >> import configure
> >> configure_options = [
> >> '--with-blaslapack-lib=-lfjlapack',
> >> '--with-debugging=0',
> >> 'CC=mpifcc',
> >> 'CXX=mpiFCC',
> >> 'FC=mpifrt',
> >> 'PETSC_ARCH=arch-arm',
> >> configure.petsc_configure(configure_options)
> >> --download-p4est --download-zlib
> >> <snip>
> >> p4est:
> >> Includes: -I/vol0004/ra010009/a04201/petsc/arch-arm/include
> >> Library: -Wl,-rpath,/vol0004/ra010009/a04201/petsc/arch-arm/lib
> >> -L/vol0004/ra010009/a04201/petsc/arch-arm/lib -lp4est -lsc
> >> Ok - this worked for me.
> >> Satish
> >> > Do you recall what nodes you use to build on a "compute" node, to avoid
> >> > cross compilation?
> >> > On Wed, Apr 14, 2021 at 12:08 PM Satish Balay <balay at mcs.anl.gov>
> >> wrote:
> >> > > looks like p4est cannot be cross-compiled.
> >> > > Satish
> >> > > > I get this error with p4est on Fugaku.
> >> > > > It is a Fortran error. Odd.
> >> > > > Mark
