[petsc-dev] Petsc: Error code  1 TS adapt difference
    Barry Smith
    bsmith at petsc.dev
    Tue Apr  6 11:53:33 CDT 2021
   Emil and Hong,
   In this test the GLEE time step adapter is making a different decision on accepting or rejecting a step. It could be due to slight differences in round-off for different machines and compilers. I leave it to our ODE experts to take a look at it.
  Barry
> On Apr 6, 2021, at 3:56 AM, Chen Gang <569615491 at qq.com> wrote:
> See the attachements. alltest.log is on a machine with 96 cores, ARM, with FC,gcc9.3.5,mpich3.4.1,fblaslapack; 6 failures
>                                  alltest2.log is on an intel machine with 40  cores,x86, without FC; icc&mkl& intel mpi; only 1 failure
> ------------------ 原始邮件 ------------------
> 发件人: "petsc-dev" <balay at mcs.anl.gov>;
> 发送时间: 2021年4月6日(星期二) 中午12:38
> 收件人: "petsc-dev"<petsc-dev at mcs.anl.gov>;
> 抄送: "Chen Gang"<569615491 at qq.com>;"cglwdm"<cglwdm at scu.edu.cn>;
> 主题: Re: [petsc-dev] Petsc: Error code 1
> Note: do not use '-j' with alltests.
> And run alltests on both machines [but *not* at the same time on machines] and send us logs from both the runs.
> Satish
> On Mon, 5 Apr 2021, Satish Balay wrote:
> > Try:
> > make alltests TIMEOUT=600
> > And send us the complete log (alltests.log)
> > Satish
> > On Tue, 6 Apr 2021, Chen Gang wrote:
> > > Dear sir,
> > > The result of make check is OK. And I do set the timeout to a larger value, which keeps me from getting timeout error. The thing is I have two machines. And I get the error code 1 in different tests on different machines.I don’t know what is error code1. What case this? How can I fix the failure tests.
> > > ------------------ Original ------------------
> > > From: Satish Balay <balay at mcs.anl.gov>
> > > Date: Tue,Apr 6,2021 0:18 PM
> > > To: Chen Gang <569615491 at qq.com>
> > > Cc: petsc-dev <petsc-dev at mcs.anl.gov>, cglwdm <cglwdm at scu.edu.cn>
> > > Subject: Re: [petsc-dev] Petsc: Error code 1
> <alltests2.log><alltests.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210406/587d18fa/attachment-0002.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210406/587d18fa/attachment-0001.obj>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210406/587d18fa/attachment-0003.html>
