[petsc-dev] -with-kokkos-cuda-arch=AMPERE80 nonsense
Barry Smith bsmith at petsc.dev
Tue Apr 6 11:27:15 CDT 2021
   Jeff,
      Likely deviceQuery provides more than enough information; sometimes it is prebuilt but it seems now it is only provided as source code so the user needs to build it (and the Makefile is huge :-)). I think it would be enough if NVIDIA just always provided prebuilt deviceQuery in a standard location.
  Barry
> On Apr 6, 2021, at 12:42 AM, Jeff Hammond <jeff.science at gmail.com> wrote:
>     Generically, independent of Kokkos,  ideally I would run a single precompiled NVIDIA program that gave me all the information about the current hardware I was running and that would provide in simple format exactly the information I needed to configure PETSc, Kokkos etc for THAT system.
> I will try to write something for you tomorrow.  For NVIDIA hardware, the sole dependency will be nvcc.
> Jeff
> Jeff Hammond
> jeff.science at gmail.com <mailto:jeff.science at gmail.com>
> http://jeffhammond.github.io/ <http://jeffhammond.github.io/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210406/b9662574/attachment.html>
