[petsc-dev] 回复:  Petsc: Error code 1
    Chen Gang
    569615491 at qq.com
    Tue Apr  6 00:48:13 CDT 2021
Dear Professor,
Attachment is the alltests.log file.
Best,
Gang
------------------ 原始邮件 ------------------
发件人:        "petsc-dev"        <balay at mcs.anl.gov>;
发送时间: 2021年4月6日(星期二) 中午12:38
收件人: "petsc-dev"<petsc-dev at mcs.anl.gov>;
抄送: "Chen Gang"<569615491 at qq.com>;"cglwdm"<cglwdm at scu.edu.cn>;
主题: Re: [petsc-dev] Petsc: Error code 1
Note: do not use '-j' with alltests.
And run alltests on both machines [but *not* at the same time on machines] and send us logs from both the runs.
Satish
On Mon, 5 Apr 2021, Satish Balay wrote:
> Try:
> make alltests TIMEOUT=600
> And send us the complete log (alltests.log)
> Satish
> On Tue, 6 Apr 2021, Chen Gang wrote:
> > Dear sir,
> > The result of make check is OK. And I do set the timeout to a larger value, which keeps me from getting timeout error. The thing is I have two machines. And I get the error code 1 in different tests on different machines.I don’t know what is error code1. What case this? How can I fix the failure tests.
> > ------------------ Original ------------------
> > From: Satish Balay <balay at mcs.anl.gov>
> > Date: Tue,Apr 6,2021 0:18 PM
> > To: Chen Gang <569615491 at qq.com>
> > Cc: petsc-dev <petsc-dev at mcs.anl.gov>, cglwdm <cglwdm at scu.edu.cn>
> > Subject: Re: [petsc-dev] Petsc: Error code 1
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210406/c401ce0e/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210406/c401ce0e/attachment.obj>
