[petsc-dev] CI failure?
    Matthew Knepley
    knepley at gmail.com
    Fri Sep 25 07:10:56 CDT 2020
It looks like a parse of the gcov output failed:
Building html files for C
1579 <https://gitlab.com/petsc/petsc/-/jobs/757483850#L1579>Traceback (most
recent call last):
1580 <https://gitlab.com/petsc/petsc/-/jobs/757483850#L1580> File
"/scratch/svcpetsc/glci-builds/LysKu_HD/0/petsc/petsc/lib/petsc/bin/maint/gcov.py",
line 403, in <module>
1581 <https://gitlab.com/petsc/petsc/-/jobs/757483850#L1581> main()
1582 <https://gitlab.com/petsc/petsc/-/jobs/757483850#L1582> File
line 397, in main
1583 <https://gitlab.com/petsc/petsc/-/jobs/757483850#L1583>
make_htmlpage(gcov_dir,petsc_dir,petsc_arch,tarballs,isCI)
1584 <https://gitlab.com/petsc/petsc/-/jobs/757483850#L1584> File
line 278, in make_htmlpage
1585 <https://gitlab.com/petsc/petsc/-/jobs/757483850#L1585> c =
int(line[line.rfind(' '):])
1586 <https://gitlab.com/petsc/petsc/-/jobs/757483850#L1586>ValueError:
invalid literal for int() with base 10: '.'
1587 <https://gitlab.com/petsc/petsc/-/jobs/757483850#L1587>make[1]: ***
[mergegcov] Error 1
1588 <https://gitlab.com/petsc/petsc/-/jobs/757483850#L1588>makefile:510:
recipe for target 'mergegcov' failed
1589 <https://gitlab.com/petsc/petsc/-/jobs/757483850#L1589>GNUmakefile:17:
1590 <https://gitlab.com/petsc/petsc/-/jobs/757483850#L1590>make: ***
[mergegcov] Error 2
1592 <https://gitlab.com/petsc/petsc/-/jobs/757483850#L1592>
  Matt
On Fri, Sep 25, 2020 at 7:45 AM Mark Adams <mfadams at lbl.gov> wrote:
> I don't see the problem here:
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200925/9a2366d5/attachment.html>
