[petsc-dev] CI format failure
    Barry Smith
    bsmith at petsc.dev
    Thu Sep 24 14:47:07 CDT 2020
  Everything in PETSc is open source and anyone is free to add/improve features.
  The only issue is that verifying the code is ok must be quick, if there are errors it is fine that the rule takes more time to nicely print out details of the problem.
  Barry
> On Sep 24, 2020, at 12:25 PM, Junchao Zhang <junchao.zhang at gmail.com> wrote:
> It is better the tool can also print out line and column numbers and reasons why it is wrong.
> --Junchao Zhang
> On Thu, Sep 24, 2020 at 11:16 AM Satish Balay via petsc-dev <petsc-dev at mcs.anl.gov <mailto:petsc-dev at mcs.anl.gov>> wrote:
> The relevant part:
> No space after if, for or while -----------------------------
> include/petscaijdevice.h
> Satish
> On Thu, 24 Sep 2020, Mark Adams wrote:
> > I have a failure here but I can't see what the problem is:
> > https://gitlab.com/petsc/petsc/-/jobs/755956828 <https://gitlab.com/petsc/petsc/-/jobs/755956828>
> > Am I missing something?
> > Thanks,
> > Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200924/7ecdfb4b/attachment.html>
