[petsc-dev] MPI derived datatype use in PETSc
Victor Eijkhout
eijkhout at tacc.utexas.edu
Wed Sep 23 12:30:10 CDT 2020
The Ohio mvapich people are working on getting better performance out of MPI datatypes. I notice that there are 5 million lines in the petsc source that reference MPI datatypes. So just as a wild guess:
Optimizations on MPI Datatypes seem to be beneficial mostly if you’re sending blocks of at least a kilobyte each. Is that a plausible usage scenario? What is the typical use of MPI Datatypes in PETSc, and what type of datatype would most benefit from optimization?
Victor.
