[petsc-dev] How to use fieldsplit for a block system with sizes change dynamically in TS
Mebratu Wakeni Mebratu.Wakeni at glasgow.ac.uk
Tue Sep 22 11:20:25 CDT 2020
Hello,
I have the following issue regarding TS and field split.
In a TS setting, I have a linear problem with the IJacobian of the IFunction with a block form
| K   0 |
| 0   D |
Where K is sparse, while D is a diagonal. The sizes of the square matrices K and D are dynamic (varying between time steps). The fact that, K and D are completely decoupled, and D is just a diagonal motivated us to use fieldsplit techniques rather than a monolithic one. However, this needs to recreate a fieldsplit preconditioner at each time step using the indices of K. To achieve this, I use the TSSetPreStep(ts, fun) function to perform the fun(TS ts) routine which does following
1.     Get indices of K,
PetscInt *idx_k; // size_of_k
2.     Create an IS corresponding to K (IS is_k) using
 ISCreatGeneral(mpiComm, size_of_k, idx_k, PETSC_COPY_VALUES, &is_k);
3.     Then set a fieldsplit preconditioner PC pc using is_k through
PCFieldSplitSetIS(pc, NULL, is_k);
4.     Finally the is_k is properly destroyed through
ISDestroy(&is_lo);
With the above setup, I have also used the following runtime options
-ts_monitor
-ts_exact_final_time stepover
-ts_dt 0.1
-ts_max_time 1
-ts_adapt_type none
-ksp_type gmres
-pc_type fieldsplit
-pc_fieldsplit_diag_use_amat
-pc_fieldsplit_type additive
-fieldsplit_0_ksp_type preonly
-fieldsplit_0_pc_type lu
-fieldsplit_0_pc_factor_mat_solver_type mumps
-fieldsplit_1_ksp_type preonly
-fieldsplit_1_pc_type jacobi
-snes_atol 1e-8
-snes_rtol 1e-12
-ksp_monitor
-snes_monitor
-snes_lag_jacobian 1
Result: with the setup described above and the options, I expect to get ksp convergence in a single step (at every time step), however, what I am getting in actuality is that the fieldsplit works as expected only for the first timestep, after that it either take too many ksp steps to converge or diverge completely. I have a suspicion that, the way the fieldsplit set up at each time using the TSSetPreStep() somehow adds new split over previous splits. For this, I have also tried using TSSetPostStep() function to reset both the ksp and pc as follows
KSPRest(ksp);
PCReset(pc);
But these don’t help either.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200922/a8f1b779/attachment.html>
