[petsc-dev] PDIPDM questions
    Barry Smith
    bsmith at petsc.dev
    Tue Sep 15 16:18:15 CDT 2020
  I see now, the TaoSetup_PDIPM() code explicitly builds the large matrix by calling MatGetRow() on the smaller matrices, no matrix abstractions at all and assuming a global AIJ storage of the large matrix.
  I think this can be made more general by building a MatNest() from the smaller matrices which allows the smaller matrices to have whatever unique structure is appropriate for them. Of course, if needed, for example, for a direct solver the MatNest can convert itself to a global AIJ matrix and get the current result.
   As Pierre rightly points out, MPIAIJ is just not a good format for many constrained optimization problems. This has been something seriously neglected in PETSc/TAO. I don't think any single format is ideal for such problems, likely hybrid formats are needed and this gets super tricky when one needs to use direct solvers such a Cholesky. If MUMPS has non-row oriented storage formats we could leverage that but I don't know if it does.
  Barry
  ierr = MatGetOwnershipRange(tao->hessian,&rjstart,NULL);CHKERRQ(ierr);
  for (i=0; i<pdipm->nx; i++){
    row = rstart + i;
    ierr = MatGetRow(tao->hessian,i+rjstart,&nc,&aj,NULL);CHKERRQ(ierr);
    proc = 0;
    for (j=0; j < nc; j++) {
      while (aj[j] >= cranges[proc+1]) proc++;
      col = aj[j] - cranges[proc] + Jranges[proc];
      ierr = MatPreallocateSet(row,1,&col,dnz,onz);CHKERRQ(ierr);
    ierr = MatRestoreRow(tao->hessian,i+rjstart,&nc,&aj,NULL);CHKERRQ(ierr);
    if (pdipm->ng) {
      /* Insert grad g' */
      ierr = MatGetRow(jac_equality_trans,i+rjstart,&nc,&aj,NULL);CHKERRQ(ierr);
      ierr = MatGetOwnershipRanges(tao->jacobian_equality,&ranges);CHKERRQ(ierr);
      proc = 0;
        /* find row ownership of */
        while (aj[j] >= ranges[proc+1]) proc++;
        nx_all = rranges[proc+1] - rranges[proc];
        col = aj[j] - ranges[proc] + Jranges[proc] + nx_all;
      ierr = MatRestoreRow(jac_equality_trans,i+rjstart,&nc,&aj,NULL);CHKERRQ(ierr);
    /* Insert Jce_xfixed^T' */
    if (pdipm->nxfixed) {
      ierr = MatGetRow(Jce_xfixed_trans,i+rjstart,&nc,&aj,NULL);CHKERRQ(ierr);
      ierr = MatGetOwnershipRanges(pdipm->Jce_xfixed,&ranges);CHKERRQ(ierr);
      proc = 0;
        col = aj[j] - ranges[proc] + Jranges[proc] + nx_all + ng_all[proc];
      ierr = MatRestoreRow(Jce_xfixed_trans,i+rjstart,&nc,&aj,NULL);CHKERRQ(ierr);
    if (pdipm->nh) {
      /* Insert -grad h' */
      ierr = MatGetRow(jac_inequality_trans,i+rjstart,&nc,&aj,NULL);CHKERRQ(ierr);
      ierr = MatGetOwnershipRanges(tao->jacobian_inequality,&ranges);CHKERRQ(ierr);
      proc = 0;
        col = aj[j] - ranges[proc] + Jranges[proc] + nx_all + nce_all[proc];
      ierr = MatRestoreRow(jac_inequality_trans,i+rjstart,&nc,&aj,NULL);CHKERRQ(ierr);
    /* Insert Jci_xb^T' */
    ierr = MatGetRow(Jci_xb_trans,i+rjstart,&nc,&aj,NULL);CHKERRQ(ierr);
    ierr = MatGetOwnershipRanges(pdipm->Jci_xb,&ranges);CHKERRQ(ierr);
    proc = 0;
      col = aj[j] - ranges[proc] + Jranges[proc] + nx_all + nce_all[proc] + nh_all[proc];
    ierr = MatRestoreRow(Jci_xb_trans,i+rjstart,&nc,&aj,NULL);CHKERRQ(ierr);
  /* 2nd Row block of KKT matrix: [grad Ce, 0, 0, 0] */
  if (pdipm->Ng) {
    ierr = MatGetOwnershipRange(tao->jacobian_equality,&rjstart,NULL);CHKERRQ(ierr);
    for (i=0; i < pdipm->ng; i++){
      row = rstart + pdipm->off_lambdae + i;
      ierr = MatGetRow(tao->jacobian_equality,i+rjstart,&nc,&aj,NULL);CHKERRQ(ierr);
      proc = 0;
        ierr = MatPreallocateSet(row,1,&col,dnz,onz);CHKERRQ(ierr); /* grad g */
      ierr = MatRestoreRow(tao->jacobian_equality,i+rjstart,&nc,&aj,NULL);CHKERRQ(ierr);
  /* Jce_xfixed */
  if (pdipm->Nxfixed) {
    ierr = MatGetOwnershipRange(pdipm->Jce_xfixed,&Jcrstart,NULL);CHKERRQ(ierr);
    for (i=0; i < (pdipm->nce - pdipm->ng); i++){
      row = rstart + pdipm->off_lambdae + pdipm->ng + i;
      ierr = MatGetRow(pdipm->Jce_xfixed,i+Jcrstart,&nc,&cols,NULL);CHKERRQ(ierr);
      if (nc != 1) SETERRQ(PETSC_COMM_SELF,PETSC_ERR_SUP,"nc != 1");
      proc = 0;
      j    = 0;
      while (cols[j] >= cranges[proc+1]) proc++;
      col = cols[j] - cranges[proc] + Jranges[proc];
      ierr = MatRestoreRow(pdipm->Jce_xfixed,i+Jcrstart,&nc,&cols,NULL);CHKERRQ(ierr);
  /* 3rd Row block of KKT matrix: [ gradCi, 0, 0, -I] */
  if (pdipm->Nh) {
    ierr = MatGetOwnershipRange(tao->jacobian_inequality,&rjstart,NULL);CHKERRQ(ierr);
    for (i=0; i < pdipm->nh; i++){
      row = rstart + pdipm->off_lambdai + i;
      ierr = MatGetRow(tao->jacobian_inequality,i+rjstart,&nc,&aj,NULL);CHKERRQ(ierr);
      proc = 0;
        ierr = MatPreallocateSet(row,1,&col,dnz,onz);CHKERRQ(ierr); /* grad h */
      ierr = MatRestoreRow(tao->jacobian_inequality,i+rjstart,&nc,&aj,NULL);CHKERRQ(ierr);
    /* -I */
      col = rstart + pdipm->off_z + i;
  /* Jci_xb */
  ierr = MatGetOwnershipRange(pdipm->Jci_xb,&Jcrstart,NULL);CHKERRQ(ierr);
  for (i=0; i < (pdipm->nci - pdipm->nh); i++){
    row = rstart + pdipm->off_lambdai + pdipm->nh + i;
    ierr = MatGetRow(pdipm->Jci_xb,i+Jcrstart,&nc,&cols,NULL);CHKERRQ(ierr);
    proc = 0;
    ierr = MatRestoreRow(pdipm->Jci_xb,i+Jcrstart,&nc,&cols,NULL);CHKERRQ(ierr);
    /* -I */
    col = rstart + pdipm->off_z + pdipm->nh + i;
  /* 4-th Row block of KKT matrix: Z and Ci */
  for (i=0; i < pdipm->nci; i++) {
    row     = rstart + pdipm->off_z + i;
    cols1[0] = rstart + pdipm->off_lambdai + i;
    cols1[1] = row;
    ierr = MatPreallocateSet(row,2,cols1,dnz,onz);CHKERRQ(ierr);
> On Sep 15, 2020, at 4:03 PM, Abhyankar, Shrirang G <shrirang.abhyankar at pnnl.gov> wrote:
> There is some code in PDIPM that copies over matrix elements from user jacobians/hessians to the big KKT matrix. I am not sure how/if that will work with MatMPI_Column. We’ll have to try out and we need an example for that 😊
> Thanks,
> Shri
> From: Barry Smith <bsmith at petsc.dev>
> Date: Tuesday, September 15, 2020 at 1:21 PM
> To: Pierre Jolivet <pierre.jolivet at enseeiht.fr>
> Cc: "Abhyankar, Shrirang G" <shrirang.abhyankar at pnnl.gov>, PETSc Development <petsc-dev at mcs.anl.gov>
> Subject: Re: [petsc-dev] PDIPDM questions
>   Pierre,
>     Based on my previous mail I am hoping that the PDIPM algorithm itself won't need a major refactorization to be scalable, only a custom matrix type is needed to store and compute with the  Hessian in a scalable way.
>    Barry
>> On Sep 15, 2020, at 12:50 PM, Pierre Jolivet <pierre.jolivet at enseeiht.fr <mailto:pierre.jolivet at enseeiht.fr>> wrote:
>>> On 15 Sep 2020, at 5:40 PM, Abhyankar, Shrirang G <shrirang.abhyankar at pnnl.gov <mailto:shrirang.abhyankar at pnnl.gov>> wrote:
>>> Pierre,
>>>    You are right. There are a few MatMultTransposeAdd that may need conforming layouts for the equality/inequality constraint vectors and equality/inequality constraint Jacobian matrices. I need to check if that’s the case. We only have ex1 example currently, we need to add more examples. We are currently working on making PDIPM robust and while doing it will work on adding another example.
>>> Very naive question, but given that I have a single constraint, how do I split a 1 x N matrix column-wise? I thought it was not possible.
>>> When setting the size of the constraint vector, you need to set the local size on one rank to 1 and all others to zero. For the Jacobian, the local row size on that rank will be 1 and all others to zero. The column layout for the Jacobian should follow the layout for vector x. So each rank will set the local column size of the Jacobian to local size of x.
>> That is assuming I don’t want x to follow the distribution of the Hessian, which is not my case.
>> Is there some plan to make PDIPM handle different layouts?
>> I hope I’m not the only one thinking that having a centralized Hessian when there is a single constraint is not scalable?
>> Thanks,
>> Pierre
>>> Shri
>>>> On 15 Sep 2020, at 2:21 AM, Abhyankar, Shrirang G <shrirang.abhyankar at pnnl.gov <mailto:shrirang.abhyankar at pnnl.gov>> wrote:
>>>> Hello Pierre,
>>>>    PDIPM works in parallel so you can have distributed Hessian, Jacobians, constraints, variables, gradients in any layout you want.  If you are using a DM then you can have it generate the Hessian.
>>> Could you please show an example where this is the case?
>>> pdipm->x, which I’m assuming is a working vector, is both used as input for Hessian and Jacobian functions, e.g., https://gitlab.com/petsc/petsc/-/blob/master/src/tao/constrained/impls/ipm/pdipm.c#L369 <https://gitlab.com/petsc/petsc/-/blob/master/src/tao/constrained/impls/ipm/pdipm.c#L369> (Hessian) + https://gitlab.com/petsc/petsc/-/blob/master/src/tao/constrained/impls/ipm/pdipm.c#L473 <https://gitlab.com/petsc/petsc/-/blob/master/src/tao/constrained/impls/ipm/pdipm.c#L473> (Jacobian)
>>> I thus doubt that it is possible to have different layouts?
>>> In practice, I end up with the following error when I try this (2 processes, distributed Hessian with centralized Jacobian):
>>> [1]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
>>> [1]PETSC ERROR: Nonconforming object sizes
>>> [1]PETSC ERROR: Vector wrong size 14172 for scatter 0 (scatter reverse and vector to != ctx from size)
>>> [1]PETSC ERROR: #1 VecScatterBegin() line 96 in /Users/jolivet/Documents/repositories/petsc/src/vec/vscat/interface/vscatfce.c
>>> [1]PETSC ERROR: #2 MatMultTransposeAdd_MPIAIJ() line 1223 in /Users/jolivet/Documents/repositories/petsc/src/mat/impls/aij/mpi/mpiaij.c
>>> [1]PETSC ERROR: #3 MatMultTransposeAdd() line 2648 in /Users/jolivet/Documents/repositories/petsc/src/mat/interface/matrix.c
>>> [0]PETSC ERROR: Nonconforming object sizes
>>> [0]PETSC ERROR: Vector wrong size 13790 for scatter 27962 (scatter reverse and vector to != ctx from size)
>>> [1]PETSC ERROR: #4 TaoSNESFunction_PDIPM() line 510 in /Users/jolivet/Documents/repositories/petsc/src/tao/constrained/impls/ipm/pdipm.c
>>> [0]PETSC ERROR: #5 TaoSolve_PDIPM() line 712 in /Users/jolivet/Documents/repositories/petsc/src/tao/constrained/impls/ipm/pdipm.c
>>> [1]PETSC ERROR: #6 TaoSolve() line 222 in /Users/jolivet/Documents/repositories/petsc/src/tao/interface/taosolver.c
>>> [0]PETSC ERROR: #1 VecScatterBegin() line 96 in /Users/jolivet/Documents/repositories/petsc/src/vec/vscat/interface/vscatfce.c
>>> [0]PETSC ERROR: #2 MatMultTransposeAdd_MPIAIJ() line 1223 in /Users/jolivet/Documents/repositories/petsc/src/mat/impls/aij/mpi/mpiaij.c
>>> [0]PETSC ERROR: #3 MatMultTransposeAdd() line 2648 in /Users/jolivet/Documents/repositories/petsc/src/mat/interface/matrix.c
>>> [0]PETSC ERROR: #4 TaoSNESFunction_PDIPM() line 510 in /Users/jolivet/Documents/repositories/petsc/src/tao/constrained/impls/ipm/pdipm.c
>>> [0]PETSC ERROR: #6 TaoSolve() line 222 in /Users/jolivet/Documents/repositories/petsc/src/tao/interface/taosolver.c
>>> I think this can be reproduced by ex1.c by just distributing the Hessian instead of having it centralized on rank 0.
>>>> Ideally, you want to have the layout below to minimize movement of matrix/vector elements across ranks.
>>>> ·         The layout of vectors x, bounds on x, and gradient is same.
>>>> ·         The row layout of the equality/inequality Jacobian is same as the equality/inequality constraint vector layout.
>>>> ·         The column layout of the equality/inequality Jacobian is same as that for x.
>>> Thanks,
>>> Pierre
>>>> ·         The row and column layout for the Hessian is same as x.
>>>> The tutorial example ex1 is extremely small (only 2 variables) so its implementation is very simplistic. I think, in parallel, it ships off constraints etc. to rank 0. It’s not an ideal example w.r.t demonstrating a parallel implementation. We aim to add more examples as we develop PDIPM. If you have an example to contribute then we would most welcome it and provide help on adding it.
>>>> Thanks,
>>>> Shri
>>>> From: petsc-dev <petsc-dev-bounces at mcs.anl.gov <mailto:petsc-dev-bounces at mcs.anl.gov>> on behalf of Pierre Jolivet <pierre.jolivet at enseeiht.fr <mailto:pierre.jolivet at enseeiht.fr>>
>>>> Date: Monday, September 14, 2020 at 1:52 PM
>>>> To: PETSc Development <petsc-dev at mcs.anl.gov <mailto:petsc-dev at mcs.anl.gov>>
>>>> Subject: [petsc-dev] PDIPDM questions
>>>> Hello,
>>>> In my quest to help users migrate from Ipopt to Tao, I’ve a new question.
>>>> When looking at src/tao/constrained/tutorials/ex1.c, it seems that almost everything is centralized on rank 0 (local sizes are 0 but on rank 0).
>>>> I’d like to have my Hessian distributed more naturally, as in (almost?) all other SNES/TS examples, but still keep the Jacobian of my equality constraint, which is of dimension 1 x N (N >> 1), centralized on rank 0.
>>>> Is this possible?
>>>> If not, is it possible to supply the transpose of the Jacobian, of dimension N x 1, which could then be distributed row-wise like the Hessian?
>>>> Or maybe use some trick to distribute a MatAIJ/MatDense of dimension 1 x N column-wise? Use a MatNest with as many blocks as processes?
>>>> So, just to sum up, how can I have a distributed Hessian with a Jacobian with a single row?
>>>> Thanks in advance for your help,
>>>> Pierre
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200915/1cefc6cf/attachment-0001.html>
