[petsc-dev] PDIPDM questions
    Barry Smith
    bsmith at petsc.dev
    Tue Sep 15 13:18:16 CDT 2020
  Pierre,
    Based on my previous mail I am hoping that the PDIPM algorithm itself won't need a major refactorization to be scalable, only a custom matrix type is needed to store and compute with the  Hessian in a scalable way.
   Barry
> On Sep 15, 2020, at 12:50 PM, Pierre Jolivet <pierre.jolivet at enseeiht.fr> wrote:
>> On 15 Sep 2020, at 5:40 PM, Abhyankar, Shrirang G <shrirang.abhyankar at pnnl.gov <mailto:shrirang.abhyankar at pnnl.gov>> wrote:
>> Pierre,
>>    You are right. There are a few MatMultTransposeAdd that may need conforming layouts for the equality/inequality constraint vectors and equality/inequality constraint Jacobian matrices. I need to check if that’s the case. We only have ex1 example currently, we need to add more examples. We are currently working on making PDIPM robust and while doing it will work on adding another example.
>> Very naive question, but given that I have a single constraint, how do I split a 1 x N matrix column-wise? I thought it was not possible.
>> When setting the size of the constraint vector, you need to set the local size on one rank to 1 and all others to zero. For the Jacobian, the local row size on that rank will be 1 and all others to zero. The column layout for the Jacobian should follow the layout for vector x. So each rank will set the local column size of the Jacobian to local size of x.
> That is assuming I don’t want x to follow the distribution of the Hessian, which is not my case.
> Is there some plan to make PDIPM handle different layouts?
> I hope I’m not the only one thinking that having a centralized Hessian when there is a single constraint is not scalable?
> Thanks,
> Pierre
>> Shri
>>> On 15 Sep 2020, at 2:21 AM, Abhyankar, Shrirang G <shrirang.abhyankar at pnnl.gov <mailto:shrirang.abhyankar at pnnl.gov>> wrote:
>>> Hello Pierre,
>>>    PDIPM works in parallel so you can have distributed Hessian, Jacobians, constraints, variables, gradients in any layout you want.  If you are using a DM then you can have it generate the Hessian.
>> Could you please show an example where this is the case?
>> pdipm->x, which I’m assuming is a working vector, is both used as input for Hessian and Jacobian functions, e.g., https://gitlab.com/petsc/petsc/-/blob/master/src/tao/constrained/impls/ipm/pdipm.c#L369 <https://gitlab.com/petsc/petsc/-/blob/master/src/tao/constrained/impls/ipm/pdipm.c#L369> (Hessian) + https://gitlab.com/petsc/petsc/-/blob/master/src/tao/constrained/impls/ipm/pdipm.c#L473 <https://gitlab.com/petsc/petsc/-/blob/master/src/tao/constrained/impls/ipm/pdipm.c#L473> (Jacobian)
>> I thus doubt that it is possible to have different layouts?
>> In practice, I end up with the following error when I try this (2 processes, distributed Hessian with centralized Jacobian):
>> [1]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
>> [1]PETSC ERROR: Nonconforming object sizes
>> [1]PETSC ERROR: Vector wrong size 14172 for scatter 0 (scatter reverse and vector to != ctx from size)
>> [1]PETSC ERROR: #1 VecScatterBegin() line 96 in /Users/jolivet/Documents/repositories/petsc/src/vec/vscat/interface/vscatfce.c
>> [1]PETSC ERROR: #2 MatMultTransposeAdd_MPIAIJ() line 1223 in /Users/jolivet/Documents/repositories/petsc/src/mat/impls/aij/mpi/mpiaij.c
>> [1]PETSC ERROR: #3 MatMultTransposeAdd() line 2648 in /Users/jolivet/Documents/repositories/petsc/src/mat/interface/matrix.c
>> [0]PETSC ERROR: Nonconforming object sizes
>> [0]PETSC ERROR: Vector wrong size 13790 for scatter 27962 (scatter reverse and vector to != ctx from size)
>> [1]PETSC ERROR: #4 TaoSNESFunction_PDIPM() line 510 in /Users/jolivet/Documents/repositories/petsc/src/tao/constrained/impls/ipm/pdipm.c
>> [0]PETSC ERROR: #5 TaoSolve_PDIPM() line 712 in /Users/jolivet/Documents/repositories/petsc/src/tao/constrained/impls/ipm/pdipm.c
>> [1]PETSC ERROR: #6 TaoSolve() line 222 in /Users/jolivet/Documents/repositories/petsc/src/tao/interface/taosolver.c
>> [0]PETSC ERROR: #1 VecScatterBegin() line 96 in /Users/jolivet/Documents/repositories/petsc/src/vec/vscat/interface/vscatfce.c
>> [0]PETSC ERROR: #2 MatMultTransposeAdd_MPIAIJ() line 1223 in /Users/jolivet/Documents/repositories/petsc/src/mat/impls/aij/mpi/mpiaij.c
>> [0]PETSC ERROR: #3 MatMultTransposeAdd() line 2648 in /Users/jolivet/Documents/repositories/petsc/src/mat/interface/matrix.c
>> [0]PETSC ERROR: #4 TaoSNESFunction_PDIPM() line 510 in /Users/jolivet/Documents/repositories/petsc/src/tao/constrained/impls/ipm/pdipm.c
>> [0]PETSC ERROR: #6 TaoSolve() line 222 in /Users/jolivet/Documents/repositories/petsc/src/tao/interface/taosolver.c
>> I think this can be reproduced by ex1.c by just distributing the Hessian instead of having it centralized on rank 0.
>>> Ideally, you want to have the layout below to minimize movement of matrix/vector elements across ranks.
>>> ·         The layout of vectors x, bounds on x, and gradient is same.
>>> ·         The row layout of the equality/inequality Jacobian is same as the equality/inequality constraint vector layout.
>>> ·         The column layout of the equality/inequality Jacobian is same as that for x.
>> Thanks,
>> Pierre
>>> ·         The row and column layout for the Hessian is same as x.
>>> The tutorial example ex1 is extremely small (only 2 variables) so its implementation is very simplistic. I think, in parallel, it ships off constraints etc. to rank 0. It’s not an ideal example w.r.t demonstrating a parallel implementation. We aim to add more examples as we develop PDIPM. If you have an example to contribute then we would most welcome it and provide help on adding it.
>>> Thanks,
>>> Shri
>>> From: petsc-dev <petsc-dev-bounces at mcs.anl.gov <mailto:petsc-dev-bounces at mcs.anl.gov>> on behalf of Pierre Jolivet <pierre.jolivet at enseeiht.fr <mailto:pierre.jolivet at enseeiht.fr>>
>>> Date: Monday, September 14, 2020 at 1:52 PM
>>> To: PETSc Development <petsc-dev at mcs.anl.gov <mailto:petsc-dev at mcs.anl.gov>>
>>> Subject: [petsc-dev] PDIPDM questions
>>> Hello,
>>> In my quest to help users migrate from Ipopt to Tao, I’ve a new question.
>>> When looking at src/tao/constrained/tutorials/ex1.c, it seems that almost everything is centralized on rank 0 (local sizes are 0 but on rank 0).
>>> I’d like to have my Hessian distributed more naturally, as in (almost?) all other SNES/TS examples, but still keep the Jacobian of my equality constraint, which is of dimension 1 x N (N >> 1), centralized on rank 0.
>>> Is this possible?
>>> If not, is it possible to supply the transpose of the Jacobian, of dimension N x 1, which could then be distributed row-wise like the Hessian?
>>> Or maybe use some trick to distribute a MatAIJ/MatDense of dimension 1 x N column-wise? Use a MatNest with as many blocks as processes?
>>> So, just to sum up, how can I have a distributed Hessian with a Jacobian with a single row?
>>> Thanks in advance for your help,
>>> Pierre
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200915/5aa1f660/attachment-0001.html>
