[petsc-dev] Very Descriptive Levels In Documentation
Jacob Faibussowitsch jacob.fai at gmail.com
Fri Sep 4 12:14:49 CDT 2020
Hello All,
I keep getting a 500 error when trying to submit a gitlab issue so ill just post it in here :(
Per major group the index is split into difficulty level, but these distinctions are ultimately either meaningless (as you need both  beginner or intermediate to perform basic tasks, or act more as artificial gatekeepers than meaningful guides. There can be more meaningful distinctions; off the top of my head for example "Create/Destroy", "Modify", "Core" "Util". Lets say for `vec`:
Create - Routines to initialize data structures
VecCreate
VecCreateMPI
VecCreate
Modify - Routines to alter behavior or data structure elements
VecSetFromOptions
VecSetValues
VecSetLocalSize
VecSeteLTOG
Core - Core routines to perform intended actions
VecAXPY
VecWAXPY
VecMDOT
Util - Routines to perform general actions
VecChop
VecCopy
VecAXPY
The point here is that this gives the reader a far better understanding of the "flow" for using various data structures. If I'm new and I want to do some action in PETSc then I want to very quickly get a general sense of how things are done. A fantastic example would be DM, which has gotten so big that you can now do a __ton__ of stuff with it that transcends the usual easy-medium-hard-nightmare difficulty levels we currently attribute to it. You can easily split that into say “create/destroy”, “solver”, “geometry” etc.
Best regards,
(Jacob Fai - booss - oh - vitch)
Cell: (312) 694-3391
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200904/7b748d1e/attachment.html>
