[petsc-dev] testharness rerun test based on error condition; GPU; gitlab issues still broken
Scott Kruger
kruger at txcorp.com
Fri Sep 4 11:48:24 CDT 2020
That's a good idea, but I'll have to think about this a bit. It seems
relatively straightforward, but I'd be doing this in bash so I'd like to
come up with an implementation that is not overly complicated. Do you
have a job that has the issue offhand?
Scott
On 9/4/20 10:27 AM, Barry Smith wrote:
> Scott,
> How difficult would it be for the test harness to run a failed test again if the return code has specific values? Instead of erroring out.
> I am thinking in particular about GPUs but it is general. If the GPU doesn't have he resources available it will error out thus crashing the entire job in the pipeline requiring retrying the job from the GUI. Wasting everyone's time.
> Seems in theory like it should be pretty straightforward but, of course, unforeseen issues can make it difficult. Just check the program's error code and it if is certain values run the program again, or wait a few seconds and run
> Barry
> Issues are still broken hence here.
Tech-X Corporation kruger at txcorp.com
5621 Arapahoe Ave, Suite A Phone: (720) 974-1841
Boulder, CO 80303 Fax: (303) 448-7756
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200904/4aabb247/attachment.html>
