[petsc-dev] [petsc-users] new book introducing PETSc for PDEs
Satish Balay
balay at mcs.anl.gov
Sat Oct 31 22:53:25 CDT 2020
On Sat, 31 Oct 2020, Ed Bueler wrote:
> Maybe I should chime in with what I am thinking. I'm not thinking dev.
> barry> I have no problem updating any of Ed's examples if we need to with
> each release, so the burden doesn't fall on him.
> It really isn't a burden to keep the small number of small codes in my repo
> up to date. I have been doing it for a couple of years now. The size of
> this "burden" scales with the number of my codes times the rapidity of
> petsc releases; I don't see why this should go out of control.
> On the other hand, keeping my codes up to date _is_ part of authoring the
> book. While these examples should be kept working with the latest petsc
> release, which forces certain changes, my goal will also be to keep them
> from drifting away from the text of the book. That is, their documentation
> is essentially fixed, so their feature/API/idiom drift should be
> minimized. E.g. I will not add functionality to the codes, even if that is
> easy to do, if it makes understanding the originally-intended functionality
> harder, as long as there is a non-deprecated idiom to keep. I'll take
> seriously all MRs (and issues) on my repo, but I may well not include the
> latest idiomatic petsc.
> If there is ever a second edition that would be the time to bring
> everything fully up to date, syncing (a subset of) the latest petsc api
> with the examples and the text of the book.
> So I guess my question about including my examples into the petsc CI is to
> ask if that is really what you want?
I guess the question is - what issues does CI address. (and the cost). And what is the alternative (and cost)
One issue is: updating the examples when interfaces change.
This can be done incrementally [as PETSc changes] and this is CI
friendly. Alternative is to make the changes at release time - in a
single go. This might be more time optimal for you [as from the above
- you have specific goals wrt what changes are ok - and what are not -
so best for petsc developers not to do these changes. so perhaps CI is
not suitable for this issue]
The other issue is: if there is a change in petsc that fundamentally
breaks the examples. And if so - know about this change immediately -
before the change is merged - and re-evaluate the change. CI is
suitable for this issue.
But this would require constant monitoring of all PETSc merge requests
[that break the examples].
> If you find that one of my codes is
> useful as a regression test then perhaps bring it over and let it evolve
> separately? Or just set up CI to let me know that there is a fail in my
> latest commit (i.e. the one that you cloned during CI), but don't make the
> whole run fail because of it, and also don't expect to merge my fixes into
> your fork?
The current CI is for feature branches - before merge to master [or
release branch - for fixes]. We can mark a test as 'ignore failure'
[so that the MR is not blocked on this failure].
There will be some coordination issues - as CI is on a feature branch
(so that the feature issues can be addressed before merge to
master). However your examples repo is likely to be in sync with
petsc/master branch (i.e after the feature is merged in). And the
complexity here is to locally test fixes for these issues [i.e
maintain a fork] - or not [let the CI have non-blocking failure until
the issue is resolved in your repo]
Also - you would need different branches for the examples repo so that they
are maintained for each of the petsc releases.
Satish
> Ed
> On Sat, Oct 31, 2020 at 2:21 PM Jed Brown <jed at jedbrown.org> wrote:
> > Barry Smith <bsmith at petsc.dev> writes:
> > each release, so the burdern doesn't fall on him. We simply make a fork of
> > his
> > >>> repository with a new branch and update that and make a MR to Ed for
> > each release and he can have a new branch or tag of his examples for each
> > new
> > >>> PETSc release.
> > >>> Barry
> > >>> We just make this part of our release process.
> > >> If we add it to CI, the workflow is
> > > I would keep the fork always petsc/pkg-eds-repo and have PETSc master
> > always point to the fork. At releases we would have release point directly
> > to eds.
> > > This would remove the need to fork constantly I use this model
> > partially for adol-c
> > > Anything wrong with this model?
> > This takes Ed out of the loop, but doesn't avoid the CI circus that I
> > outlined. It's more reproducible to always pin to a commit hash in the
> > repository, in which case there may be no need to circle back and update
> > PETSc after merging in Ed's repo (or our fork).
> > An alternative would be to subtree the examples into PETSc and export upon
> > release. Ed could be the CODEOWNER so he can weigh in on proposed changes
> > or more idiomatic interfaces that may become available. His repo would
> > always work with the latest release.
