[petsc-dev] behavior of PetscDefined(PETSC_HAVE_CUDA)
Jed Brown
jed at jedbrown.org
Thu Oct 15 22:39:37 CDT 2020
Mark Adams <mfadams at lbl.gov> writes:
> I have:
> #if defined(PETSC_HAVE_CUDA)
> ierr = PetscInfo3(pc,"PETSC_HAVE_CUDA ---------------------Test:
> factor=%D. cuda=%D
> level=%D\n",pc_gamg->level_reduction_factors[pc_gamg->current_level],
> *PetscDefined(PETSC_HAVE_CUDA)*,pc_gamg->current_level);CHKERRQ(ierr);
> #endif
> and see:
> [0] PCGAMGCreateLevel_GAMG(): PETSC_HAVE_CUDA ---------------------Test:
> factor=2.* cuda=0* level=0
> So PETSC_HAVE_CUDA is defined yet PetscDefined(PETSC_HAVE_CUDA) is 0. Am I
> missing something?
The syntax is PetscDefined(HAVE_CUDA). This is explained by way of example in the man page, but perhaps it should be explicitly repeated.
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscDefined.html
