[petsc-dev] Kokkos initialize
    Mark Adams
    mfadams at lbl.gov
    Thu Oct 15 21:44:51 CDT 2020
Si it seems like these two calls in cupminit.inc are inconsistent with lazy:
22:41 adams/gamg-reduce-opt-cuda *= ~/petsc$ git grep PetscBeganKokkos
src/sys/objects/cupminit.inc:    PetscBeganKokkos = PETSC_TRUE;
I can do an MR to remove these if that is the case.
On Thu, Oct 15, 2020 at 8:34 PM Barry Smith <bsmith at petsc.dev> wrote:
>   I thought the plan was that Kokkos also had a lazy initialization but
> perhaps it does not and needs to be fixed.
>   Barry
> > On Oct 15, 2020, at 6:49 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > I am running a on SUMMIt with a Kokkos cuda configuration and while
> debugging with ddt I noticed that it spent a long time in KokkosInit, but I
> was not using Kokkos. KokkosInit was call in PETSc's GPU init, which seems
> logical enough, but it would be better if it is not called if you are not
> using Kokkos.
> > I recall seeing places where Kokkos is checked when calling a Kokkos
> method (ie, lazy initialization). Do we have policy on whether we are being
> lazy with KokkosInit or not?
> > Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201015/9c875007/attachment.html>
