[petsc-dev] please send to systems ASAP
    Satish Balay
    balay at mcs.anl.gov
    Mon Oct 12 10:55:02 CDT 2020
Fixed now.
Satish
On Mon, 12 Oct 2020, Satish Balay wrote:
> I can reproduce (on chrome) - so sent it over to systems on slack
> Satish
> On Mon, 12 Oct 2020, Barry Smith wrote:
> > Satish,
> >    Please send to systems ASAP. The PETSc webpages will not work for many people because of (for example Safari simply refuses to go).
> > Your connection is not private
> > This server could not prove that it is www.mcs.anl.gov; its security certificate expired 2 days ago. This may be caused by a misconfiguration or an attacker intercepting your connection. Your computer's clock is currently set to Monday, October 12, 2020. Does that look right? If not, you should correct your system's clock and then refresh this page.
> > NET::ERR_CERT_DATE_INVALID
> > Back to safety
