[petsc-dev] please send to systems ASAP
    Barry Smith
    bsmith at petsc.dev
    Mon Oct 12 10:15:49 CDT 2020
Satish,
   Please send to systems ASAP. The PETSc webpages will not work for many people because of (for example Safari simply refuses to go).
Your connection is not private
This server could not prove that it is www.mcs.anl.gov; its security certificate expired 2 days ago. This may be caused by a misconfiguration or an attacker intercepting your connection. Your computer's clock is currently set to Monday, October 12, 2020. Does that look right? If not, you should correct your system's clock and then refresh this page.
NET::ERR_CERT_DATE_INVALID
Back to safety
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201012/9347363d/attachment.html>
