[petsc-dev] PETSc always recompiles mpi4py petsc4py even when it does not have too
    Barry Smith
    bsmith at petsc.dev
    Sun Oct 11 03:35:09 CDT 2020
> On Oct 11, 2020, at 2:50 AM, Pierre Jolivet <pierre at joliv.et> wrote:
> This actually applies to all packages with builtafterpetsc = 1.
  Yes, but now that petsc4py is part of the PETSc repository I would like to just alway have it turned on so now the rebuild is annoying.
> I think you want to do make libs instead of make all?
  The problem is make libs is not parallel so much slower?
  Barry
> Thanks,
> Pierre
>> On 11 Oct 2020, at 9:36 AM, Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>>   I change a single PETSc file and do make all that single file gets compiled but all of mpi4py and petsc4py get recompiled even though I have not changed any thing to affect them. No include files for example
>> *** Building mpi4py ***
>> *** Installing mpi4py ***
>> To use mpi4py, add /Users/barrysmith/Src/petsc/arch-cleanup-dmd-domaindecomposition/lib to PYTHONPATH
>> *** Building petsc4py ***
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201011/6cadfce9/attachment-0001.html>
