[petsc-dev] Failure of mergecov
    Matthew Knepley
    knepley at gmail.com
    Sat Oct 10 12:37:16 CDT 2020
I know get a different error:
$ make mergegcov
ssh: Could not resolve hostname +master: Name or service not known
fatal: Could not read from remote repository.
Please make sure you have the correct access rights
and the repository exists.
Usage: gcov.py [options]
gcov.py: error: --merge_branch option requires 1 argument
make[1]: *** [mergegcov] Error 2
makefile:518: recipe for target 'mergegcov' failed
GNUmakefile:17: recipe for target 'mergegcov' failed
make: *** [mergegcov] Error 2
Running after_script
00:01
The system default contains no modules
  (env var: LMOD_SYSTEM_DEFAULT_MODULES is empty)
  No changes in loaded modules
Uploading artifacts for failed job
00:06
     Matt
On Thu, Oct 8, 2020 at 10:04 PM Satish Balay via petsc-dev <
petsc-dev at mcs.anl.gov> wrote:
> MR at: https://gitlab.com/petsc/petsc/-/merge_requests/3327
> Satish
> On Thu, 8 Oct 2020, Barry Smith wrote:
> >   Yes, I think Satish's fix is correct.
> >   Barry
> > > On Oct 8, 2020, at 4:54 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > >> fatal: ambiguous argument 'origin/master...': unknown revision or
> path not in the working tree.
> > > Likely a bug in this check [which I think is expected to create
> origin/master in the clone] ..
> > > Satish
> > > diff --git a/lib/petsc/bin/maint/check-merge-branch.sh
> b/lib/petsc/bin/maint/check-merge-branch.sh
> > > index f590b9c646..3ba477c4af 100755
> > > --- a/lib/petsc/bin/maint/check-merge-branch.sh
> > > +++ b/lib/petsc/bin/maint/check-merge-branch.sh
> > > @@ -1,6 +1,7 @@
> > > #!/bin/bash -e
> > > if [ ! -z ${CI_MERGE_REQUEST_TARGET_BRANCH_NAME+x} ]; then
> > > +  git fetch -q --unshallow --no-tags
> +${CI_MERGE_REQUEST_TARGET_BRANCH_NAME}:remotes/origin/${CI_MERGE_REQUEST_TARGET_BRANCH_NAME}
> > >   echo origin/${CI_MERGE_REQUEST_TARGET_BRANCH_NAME}
> > >   exit 0
> > > fi
> > >> git diff --name-only origin/master...' returned non-zero exit status
> 128.
> > >>  I did a retry, let's see if that works.
> > >>  I can protect this with a try so it won't crash CI and waste
> people's time.
> > >>  I'll look at the log more closely later and see if I guess the cause.
> > >>  Barry
> > >>> On Oct 8, 2020, at 3:03 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
> > >>> Barry, I got this
> > >>>  https://gitlab.com/petsc/petsc/-/jobs/780244679 <
> https://gitlab.com/petsc/petsc/-/jobs/780244679>
> > >>> in this pipeline analysis
> > >>>  https://gitlab.com/petsc/petsc/-/pipelines/199842334 <
> https://gitlab.com/petsc/petsc/-/pipelines/199842334>
> > >>> I did not use the CI issue because this is about code.
> > >>>  Thanks,
> > >>>     Matt
> > >>> What most experimenters take for granted before they begin their
> experiments lead.
> > >>> -- Norbert Wiener
> > >>> https://www.cse.buffalo.edu/~knepley/ <
> http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201010/df3cdc04/attachment.html>
