[petsc-dev] why does the Ubuntu PETSc package install coarray Fortran?
Jed Brown
jed at jedbrown.org
Sun May 31 22:57:32 CDT 2020
Satish Balay via petsc-dev <petsc-dev at mcs.anl.gov> writes:
> This is likely a dependency of a dependency.
Jeff, you can
apt install --no-install-recommends petsc-dev
The recommendation comes from libopenmpi-dev:
https://packages.debian.org/buster/libopenmpi-dev
I'd estimate an exceedingly small fraction of libopenmpi-dev users
actually use coarray Fortran so the recommendation might be wishful
thinking from Alastair.
