[petsc-dev] MATOP_MAT_MULT
    Jose E. Roman
    jroman at dsic.upv.es
    Sun May 10 12:56:40 CDT 2020
> El 10 may 2020, a las 19:42, Stefano Zampini <stefano.zampini at gmail.com> escribió:
> Glad to hear it works. Anyway, without the MatShellVecSetType call the code was erroring for me, not leaking memory.
> Where you also providing -vec_type cuda at command line or what?
> Mark recently noted a similar leak, and I was wondering what was the cause for yours. A MWE would be great.
I never use -vec_type cuda because all SLEPc tests that use CUDA create vectors with MatCreateVecs(). Until now I had never tested examples with shell matrices.
This kind of issues would be more easy to detect if macros such as PetscCheckSameTypeAndComm() would actually compare type_name.
> BTW, the branch also provide MatDenseReplaceArray() now.
Yes, I saw it. Thanks.
> Last thing I want to do is to support the user to provide MatMat (AB and AtB at least) callbacks for MATSHELL
> Can SLEPc benefit from such a feature ?
Some solvers yes.
>> On May 10, 2020, at 7:47 PM, Jose E. Roman <jroman at dsic.upv.es> wrote:
>> Thanks for the hints. I have modified my branch. I was missing the MatShellSetVecType() call. Now everything works fine and all tests are clean.
>> Jose
>>> El 9 may 2020, a las 21:32, Stefano Zampini <stefano.zampini at gmail.com> escribió:
>>> Jose
>>> I have just pushed an updated example with the MatMat operation, and I do not see the memory leak. Can you check?
>>> zampins at jasmine:~/petsc$ make -f gmakefile.test test search='mat%' searchin='ex69' PETSC_OPTIONS='-malloc -malloc_dump -malloc_debug'
>>> /usr/bin/python /home/zampins/petsc/config/gmakegentest.py --petsc-dir=/home/zampins/petsc --petsc-arch=arch-gpu-double-openmp-openblas --testdir=./arch-gpu-double-openmp-openblas/tests
>>> Using MAKEFLAGS: -- PETSC_OPTIONS=-malloc -malloc_dump -malloc_debug searchin=ex69 search=mat%
>>>         CC arch-gpu-double-openmp-openblas/tests/mat/tests/ex69.o
>>>    CLINKER arch-gpu-double-openmp-openblas/tests/mat/tests/ex69
>>>       TEST arch-gpu-double-openmp-openblas/tests/counts/mat_tests-ex69_1.counts
>>> ok mat_tests-ex69_1+nsize-1test-0_l-0_use_shell-0
>>> ok diff-mat_tests-ex69_1+nsize-1test-0_l-0_use_shell-0
>>> ok mat_tests-ex69_1+nsize-1test-0_l-0_use_shell-1
>>> ok diff-mat_tests-ex69_1+nsize-1test-0_l-0_use_shell-1
>>> ok mat_tests-ex69_1+nsize-1test-0_l-5_use_shell-0
>>> ok diff-mat_tests-ex69_1+nsize-1test-0_l-5_use_shell-0
>>> ok mat_tests-ex69_1+nsize-1test-0_l-5_use_shell-1
>>> ok diff-mat_tests-ex69_1+nsize-1test-0_l-5_use_shell-1
>>> ok mat_tests-ex69_1+nsize-1test-1_l-0_use_shell-0
>>> ok diff-mat_tests-ex69_1+nsize-1test-1_l-0_use_shell-0
>>> ok mat_tests-ex69_1+nsize-1test-1_l-0_use_shell-1
>>> ok diff-mat_tests-ex69_1+nsize-1test-1_l-0_use_shell-1
>>> ok mat_tests-ex69_1+nsize-1test-1_l-5_use_shell-0
>>> ok diff-mat_tests-ex69_1+nsize-1test-1_l-5_use_shell-0
>>> ok mat_tests-ex69_1+nsize-1test-1_l-5_use_shell-1
>>> ok diff-mat_tests-ex69_1+nsize-1test-1_l-5_use_shell-1
>>> ok mat_tests-ex69_1+nsize-1test-2_l-0_use_shell-0
>>> ok diff-mat_tests-ex69_1+nsize-1test-2_l-0_use_shell-0
>>> ok mat_tests-ex69_1+nsize-1test-2_l-0_use_shell-1
>>> ok diff-mat_tests-ex69_1+nsize-1test-2_l-0_use_shell-1
>>> ok mat_tests-ex69_1+nsize-1test-2_l-5_use_shell-0
>>> ok diff-mat_tests-ex69_1+nsize-1test-2_l-5_use_shell-0
>>> ok mat_tests-ex69_1+nsize-1test-2_l-5_use_shell-1
>>> ok diff-mat_tests-ex69_1+nsize-1test-2_l-5_use_shell-1
>>> ok mat_tests-ex69_1+nsize-2test-0_l-0_use_shell-0
>>> ok diff-mat_tests-ex69_1+nsize-2test-0_l-0_use_shell-0
>>> ok mat_tests-ex69_1+nsize-2test-0_l-0_use_shell-1
>>> ok diff-mat_tests-ex69_1+nsize-2test-0_l-0_use_shell-1
>>> ok mat_tests-ex69_1+nsize-2test-0_l-5_use_shell-0
>>> ok diff-mat_tests-ex69_1+nsize-2test-0_l-5_use_shell-0
>>> ok mat_tests-ex69_1+nsize-2test-0_l-5_use_shell-1
>>> ok diff-mat_tests-ex69_1+nsize-2test-0_l-5_use_shell-1
>>> ok mat_tests-ex69_1+nsize-2test-1_l-0_use_shell-0
>>> ok diff-mat_tests-ex69_1+nsize-2test-1_l-0_use_shell-0
>>> ok mat_tests-ex69_1+nsize-2test-1_l-0_use_shell-1
>>> ok diff-mat_tests-ex69_1+nsize-2test-1_l-0_use_shell-1
>>> ok mat_tests-ex69_1+nsize-2test-1_l-5_use_shell-0
>>> ok diff-mat_tests-ex69_1+nsize-2test-1_l-5_use_shell-0
>>> ok mat_tests-ex69_1+nsize-2test-1_l-5_use_shell-1
>>> ok diff-mat_tests-ex69_1+nsize-2test-1_l-5_use_shell-1
>>> ok mat_tests-ex69_1+nsize-2test-2_l-0_use_shell-0
>>> ok diff-mat_tests-ex69_1+nsize-2test-2_l-0_use_shell-0
>>> ok mat_tests-ex69_1+nsize-2test-2_l-0_use_shell-1
>>> ok diff-mat_tests-ex69_1+nsize-2test-2_l-0_use_shell-1
>>> ok mat_tests-ex69_1+nsize-2test-2_l-5_use_shell-0
>>> ok diff-mat_tests-ex69_1+nsize-2test-2_l-5_use_shell-0
>>> ok mat_tests-ex69_1+nsize-2test-2_l-5_use_shell-1
>>> ok diff-mat_tests-ex69_1+nsize-2test-2_l-5_use_shell-1
>>> #   Summary
>>> # success 48/48 tests (100.0%)
>>> # failed 0/48 tests (0.0%)
>>> # todo 0/48 tests (0.0%)
>>> # skip 0/48 tests (0.0%)
>>> # Wall clock time for tests: 58 sec
>>> # Approximate CPU time (not incl. build time): 62.11 sec
>>> # Timing summary (actual test time / total CPU time):
>>> #   mat_tests-ex69_1: 2.30 sec / 62.11 sec
>>>> On May 9, 2020, at 9:28 PM, Jose E. Roman <jroman at dsic.upv.es> wrote:
>>>>> El 9 may 2020, a las 20:00, Stefano Zampini <stefano.zampini at gmail.com> escribió:
>>>>> Il giorno sab 9 mag 2020 alle ore 19:43 Jose E. Roman <jroman at dsic.upv.es> ha scritto:
>>>>>> El 9 may 2020, a las 12:45, Stefano Zampini <stefano.zampini at gmail.com> escribió:
>>>>>> Jose
>>>>>> I have just pushed a test https://gitlab.com/petsc/petsc/-/blob/d64c2bc63c8d5d1a8c689f1abc762ae2722bba26/src/mat/tests/ex69.c
>>>>>> See if it fits your framework, and feel free to modify the test to add more checks
>>>>> Almost good. The following modification of the example fails with -test 1:
>>>>> diff --git a/src/mat/tests/ex69.c b/src/mat/tests/ex69.c
>>>>> index e562f1e2e3..2df2c89be1 100644
>>>>> --- a/src/mat/tests/ex69.c
>>>>> +++ b/src/mat/tests/ex69.c
>>>>> @@ -84,6 +84,10 @@ int main(int argc,char **argv)
>>>>> ierr = VecCUDARestoreArray(v,&vv);CHKERRQ(ierr);
>>>>> +  if (test==1) {
>>>>> +    ierr = MatDenseCUDAGetArray(B,&aa);CHKERRQ(ierr);
>>>>> +    if (aa) SETERRQ(PETSC_COMM_WORLD,PETSC_ERR_USER,"Expected a null pointer");
>>>>> /* free work space */
>>>>> ierr = MatDestroy(&B);CHKERRQ(ierr);
>>>>> I would expect that after MatDenseCUDAResetArray() the pointer is NULL because it was set so in line 60. In the CPU counterpart it works as expected.
>>>>> Pushed a fix for this, thanks.
>>>>> Another comment is: in line 60 you have changed MatDenseCUDAPlaceArray() to MatDenseCUDAReplaceArray(). This is ok, but it is strange because MatDenseReplaceArray() does not exist. So the interface is different in GPU vs CPU, but I guess it is necessary here.
>>>>> I think we do not support calling PlaceArray twice anywhere PETSc. This is why I have added MatDenseCUDAReplaceArray(). If you need support for the CPU case too, I can add it.
>>>> Yes, please. It is better to have the same thing in both cases.
>>>> I am attaching the modified example, now performs a mat-mat product. If I do A*B it works well, but if I replace A with a shell matrix I get a memory leak.
>>>> [ 0]32 bytes VecCUDAAllocateCheck() line 34 in /home/users/proy/copa/jroman/soft/petsc/src/vec/vec/impls/seq/seqcuda/veccuda2.cu
>>>>> Thanks.
>>>>> Jose
>>>>>> Il giorno ven 8 mag 2020 alle ore 18:48 Jose E. Roman <jroman at dsic.upv.es> ha scritto:
>>>>>> Attached. Run with -test 1 or -test 2
>>>>>>> El 8 may 2020, a las 17:14, Stefano Zampini <stefano.zampini at gmail.com> escribió:
>>>>>>> Jose
>>>>>>> Just send me a MWE and I’ll fix the case for you
>>>>>>> Thanks
>>>>>>> Stefano
>>>>>> Stefano
>>>>> Stefano
>>>> <ex69.c>
