[petsc-dev] MATOP_MAT_MULT
    Jose E. Roman
    jroman at dsic.upv.es
    Sun May 10 11:47:35 CDT 2020
Thanks for the hints. I have modified my branch. I was missing the MatShellSetVecType() call. Now everything works fine and all tests are clean.
Jose
> El 9 may 2020, a las 21:32, Stefano Zampini <stefano.zampini at gmail.com> escribió:
> Jose
> I have just pushed an updated example with the MatMat operation, and I do not see the memory leak. Can you check?
> zampins at jasmine:~/petsc$ make -f gmakefile.test test search='mat%' searchin='ex69' PETSC_OPTIONS='-malloc -malloc_dump -malloc_debug'
> /usr/bin/python /home/zampins/petsc/config/gmakegentest.py --petsc-dir=/home/zampins/petsc --petsc-arch=arch-gpu-double-openmp-openblas --testdir=./arch-gpu-double-openmp-openblas/tests
> Using MAKEFLAGS: -- PETSC_OPTIONS=-malloc -malloc_dump -malloc_debug searchin=ex69 search=mat%
>           CC arch-gpu-double-openmp-openblas/tests/mat/tests/ex69.o
>      CLINKER arch-gpu-double-openmp-openblas/tests/mat/tests/ex69
>         TEST arch-gpu-double-openmp-openblas/tests/counts/mat_tests-ex69_1.counts
>  ok mat_tests-ex69_1+nsize-1test-0_l-0_use_shell-0
>  ok diff-mat_tests-ex69_1+nsize-1test-0_l-0_use_shell-0
>  ok mat_tests-ex69_1+nsize-1test-0_l-0_use_shell-1
>  ok diff-mat_tests-ex69_1+nsize-1test-0_l-0_use_shell-1
>  ok mat_tests-ex69_1+nsize-1test-0_l-5_use_shell-0
>  ok diff-mat_tests-ex69_1+nsize-1test-0_l-5_use_shell-0
>  ok mat_tests-ex69_1+nsize-1test-0_l-5_use_shell-1
>  ok diff-mat_tests-ex69_1+nsize-1test-0_l-5_use_shell-1
>  ok mat_tests-ex69_1+nsize-1test-1_l-0_use_shell-0
>  ok diff-mat_tests-ex69_1+nsize-1test-1_l-0_use_shell-0
>  ok mat_tests-ex69_1+nsize-1test-1_l-0_use_shell-1
>  ok diff-mat_tests-ex69_1+nsize-1test-1_l-0_use_shell-1
>  ok mat_tests-ex69_1+nsize-1test-1_l-5_use_shell-0
>  ok diff-mat_tests-ex69_1+nsize-1test-1_l-5_use_shell-0
>  ok mat_tests-ex69_1+nsize-1test-1_l-5_use_shell-1
>  ok diff-mat_tests-ex69_1+nsize-1test-1_l-5_use_shell-1
>  ok mat_tests-ex69_1+nsize-1test-2_l-0_use_shell-0
>  ok diff-mat_tests-ex69_1+nsize-1test-2_l-0_use_shell-0
>  ok mat_tests-ex69_1+nsize-1test-2_l-0_use_shell-1
>  ok diff-mat_tests-ex69_1+nsize-1test-2_l-0_use_shell-1
>  ok mat_tests-ex69_1+nsize-1test-2_l-5_use_shell-0
>  ok diff-mat_tests-ex69_1+nsize-1test-2_l-5_use_shell-0
>  ok mat_tests-ex69_1+nsize-1test-2_l-5_use_shell-1
>  ok diff-mat_tests-ex69_1+nsize-1test-2_l-5_use_shell-1
>  ok mat_tests-ex69_1+nsize-2test-0_l-0_use_shell-0
>  ok diff-mat_tests-ex69_1+nsize-2test-0_l-0_use_shell-0
>  ok mat_tests-ex69_1+nsize-2test-0_l-0_use_shell-1
>  ok diff-mat_tests-ex69_1+nsize-2test-0_l-0_use_shell-1
>  ok mat_tests-ex69_1+nsize-2test-0_l-5_use_shell-0
>  ok diff-mat_tests-ex69_1+nsize-2test-0_l-5_use_shell-0
>  ok mat_tests-ex69_1+nsize-2test-0_l-5_use_shell-1
>  ok diff-mat_tests-ex69_1+nsize-2test-0_l-5_use_shell-1
>  ok mat_tests-ex69_1+nsize-2test-1_l-0_use_shell-0
>  ok diff-mat_tests-ex69_1+nsize-2test-1_l-0_use_shell-0
>  ok mat_tests-ex69_1+nsize-2test-1_l-0_use_shell-1
>  ok diff-mat_tests-ex69_1+nsize-2test-1_l-0_use_shell-1
>  ok mat_tests-ex69_1+nsize-2test-1_l-5_use_shell-0
>  ok diff-mat_tests-ex69_1+nsize-2test-1_l-5_use_shell-0
>  ok mat_tests-ex69_1+nsize-2test-1_l-5_use_shell-1
>  ok diff-mat_tests-ex69_1+nsize-2test-1_l-5_use_shell-1
>  ok mat_tests-ex69_1+nsize-2test-2_l-0_use_shell-0
>  ok diff-mat_tests-ex69_1+nsize-2test-2_l-0_use_shell-0
>  ok mat_tests-ex69_1+nsize-2test-2_l-0_use_shell-1
>  ok diff-mat_tests-ex69_1+nsize-2test-2_l-0_use_shell-1
>  ok mat_tests-ex69_1+nsize-2test-2_l-5_use_shell-0
>  ok diff-mat_tests-ex69_1+nsize-2test-2_l-5_use_shell-0
>  ok mat_tests-ex69_1+nsize-2test-2_l-5_use_shell-1
>  ok diff-mat_tests-ex69_1+nsize-2test-2_l-5_use_shell-1
> #   Summary
> # success 48/48 tests (100.0%)
> # failed 0/48 tests (0.0%)
> # todo 0/48 tests (0.0%)
> # skip 0/48 tests (0.0%)
> # Wall clock time for tests: 58 sec
> # Approximate CPU time (not incl. build time): 62.11 sec
> # Timing summary (actual test time / total CPU time):
> #   mat_tests-ex69_1: 2.30 sec / 62.11 sec
>> On May 9, 2020, at 9:28 PM, Jose E. Roman <jroman at dsic.upv.es> wrote:
>>> El 9 may 2020, a las 20:00, Stefano Zampini <stefano.zampini at gmail.com> escribió:
>>> Il giorno sab 9 mag 2020 alle ore 19:43 Jose E. Roman <jroman at dsic.upv.es> ha scritto:
>>>> El 9 may 2020, a las 12:45, Stefano Zampini <stefano.zampini at gmail.com> escribió:
>>>> Jose
>>>> I have just pushed a test https://gitlab.com/petsc/petsc/-/blob/d64c2bc63c8d5d1a8c689f1abc762ae2722bba26/src/mat/tests/ex69.c
>>>> See if it fits your framework, and feel free to modify the test to add more checks
>>> Almost good. The following modification of the example fails with -test 1:
>>> diff --git a/src/mat/tests/ex69.c b/src/mat/tests/ex69.c
>>> index e562f1e2e3..2df2c89be1 100644
>>> --- a/src/mat/tests/ex69.c
>>> +++ b/src/mat/tests/ex69.c
>>> @@ -84,6 +84,10 @@ int main(int argc,char **argv)
>>>   ierr = VecCUDARestoreArray(v,&vv);CHKERRQ(ierr);
>>> +  if (test==1) {
>>> +    ierr = MatDenseCUDAGetArray(B,&aa);CHKERRQ(ierr);
>>> +    if (aa) SETERRQ(PETSC_COMM_WORLD,PETSC_ERR_USER,"Expected a null pointer");
>>>   /* free work space */
>>>   ierr = MatDestroy(&B);CHKERRQ(ierr);
>>> I would expect that after MatDenseCUDAResetArray() the pointer is NULL because it was set so in line 60. In the CPU counterpart it works as expected.
>>> Pushed a fix for this, thanks.
>>> Another comment is: in line 60 you have changed MatDenseCUDAPlaceArray() to MatDenseCUDAReplaceArray(). This is ok, but it is strange because MatDenseReplaceArray() does not exist. So the interface is different in GPU vs CPU, but I guess it is necessary here.
>>> I think we do not support calling PlaceArray twice anywhere PETSc. This is why I have added MatDenseCUDAReplaceArray(). If you need support for the CPU case too, I can add it.
>> Yes, please. It is better to have the same thing in both cases.
>> I am attaching the modified example, now performs a mat-mat product. If I do A*B it works well, but if I replace A with a shell matrix I get a memory leak.
>> [ 0]32 bytes VecCUDAAllocateCheck() line 34 in /home/users/proy/copa/jroman/soft/petsc/src/vec/vec/impls/seq/seqcuda/veccuda2.cu
>>> Thanks.
>>> Jose
>>>> Il giorno ven 8 mag 2020 alle ore 18:48 Jose E. Roman <jroman at dsic.upv.es> ha scritto:
>>>> Attached. Run with -test 1 or -test 2
>>>>> El 8 may 2020, a las 17:14, Stefano Zampini <stefano.zampini at gmail.com> escribió:
>>>>> Jose
>>>>> Just send me a MWE and I’ll fix the case for you
>>>>> Thanks
>>>>> Stefano
>>>> Stefano
>>> Stefano
>> <ex69.c>
