[petsc-dev] Should PetscSignalHandlerDefault avoid calling MPI_Abort?
John Peterson jwpeterson at gmail.com
Wed May 6 10:22:02 CDT 2020
Hi Junchao,
I was just wondering if there was any update on this? I saw your question
on the discuss at mpich thread, but I gather you have not received a response
yet.
John
On Tue, Apr 21, 2020 at 10:09 PM Junchao Zhang <junchao.zhang at gmail.com>
wrote:
>   I don't see problems calling _exit in PetscSignalHandlerDefault. Let me
> try it first.
> --Junchao Zhang
> On Tue, Apr 21, 2020 at 3:17 PM John Peterson <jwpeterson at gmail.com>
> wrote:
>> Hi,
>> I started a thread on discuss at mpich.org regarding some hanging canceled
>> jobs that we were seeing:
>> https://lists.mpich.org/pipermail/discuss/2020-April/005910.html
>> It turns out that there are some fairly strict rules about what types of
>> functions (asynchronous-safe only) can be called from signal handlers, and
>> MPI_Abort(), at least the mpich implementation of it, apparently does not
>> fall into that category. I wonder if you have any comments on this. One
>> possibility might be might be to just call "_exit" from
>> PetscSignalHandlerDefault rather than PETSCABORT, not sure what other
>> issues that would cause, however.
>> Thanks,
>> John
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200506/645571da/attachment.html>
