[petsc-dev] MATOP_MAT_MULT
Stefano Zampini
stefano.zampini at gmail.com
Wed May 6 09:52:42 CDT 2020
I have working support for MATSHELL here
https://gitlab.com/petsc/petsc/-/commit/146e7f1ccf5f267b36079cac494077a23e8bbc45
Tested here
https://gitlab.com/petsc/petsc/-/commit/c4fcaa45a01cc783c629913983b204a1cbcb3939
Jose and Pierre, this code is supposed to work with CUDA, but I haven't
tested it yet
Can you tell me if this fixes the issues for you to not have to loop over
the columns of the dense matrix yourself?
Il giorno mer 6 mag 2020 alle ore 10:09 Stefano Zampini <
stefano.zampini at gmail.com> ha scritto:
> Hong
> If the product is not supported, the type of C will never be set anyway,
> so you cannot call MatHasOperation after MatProductSetFromOptions.
> The purpose of MatProductSetFromOptions is to populate the function
> pointers for symbolic and numeric phases. If not found, they should be set
> to null instead of erroring as it is now.
> What I propose is to have MatProductHasOperation (not MatHasOperation):
> this function will be identical to MatHasOperation, with the only
> difference that does not call PetscValidType on the input mat.
> Meanwhile, I’m coding a basic MatMat (and MatTransposeMat) driver to loop
> over dense columns and apply MatMult. (Or MatMultTranspose) without memory
> movement.
> This will be valid for all B matrices being of type dense (and its
> derivations), with C of type dense too. This in principle will fix Jose and
> Pierre’s issues (they can correct me if I’m wrong)
> However, we should definitely have a way for the user to enquire if a
> given operation is supported or not.
> Thanks
> Stefano
> On May 6, 2020, at 12:03 AM, Zhang, Hong <hzhang at mcs.anl.gov> wrote:
> Stefano:
> Now, we need address this bug report: enable
> MatHasOperation(C,MATOP_MAT_MULT,&flg) for matrix products, e.g., C=A*B,
> which is related to your issue https://gitlab.com/petsc/petsc/-/issues/608
> In petsc-3.13:
> 1) MATOP_MAT_MULT, ..., MATOP_MATMAT_MULT are removed from the MATOP
> table (they are still listed in petscmat.h -- an overlook, I'll remove
> them).
> MATOP_MAT_MULT_SYMBOLIC/NUMERIC ... are still in the table.
> 2) MatHasOperation(C,...) must be called for the matrix product C, not
> matrix A or B (slepc needs to fix this after this reported bug is fixed).
> Like MatSetOption(), MatHasOperation() must be called AFTER MatSetType().
> You moved MatSetType() from MatProductSetFromOptions() back to MatProductSymbolic()
> in your latest patch, thus user has to call MatHasOption() after
> MatProductSymbolic():
> MatProductCreate(A,B,NULL,&C);
> MatProductSetType(C,...);
> MatProductSetFromOptions(); //if the product is not supported for the
> given mat types, currently petsc crashes here, which we can replace with an
> error output
> MatProductSymbloc(); -> call MatSetType()
> Question: how to call MatHasOperation(C,..) when MatProductSymbloc() is
> not supported?
> My fix to this bug:
> Resume MatSetType() in MatProductSetFromOptions(). Then user calls:
> MatProductSetFromOptions(C); //if the product is not supported for the
> given mat types, C->ops->productsymbolic=NULL;
> MatHasOperation(C,MATOP_PRODUCTSYMBOLIC,&flg);
> if (flg) {
> MatProductSymbolic(C);
> } else {
> MatDestroy(&C);
> Either you take care of this bug report, or let me know your thoughts
> about how to fix this bug.
> Hong
> *From:* Zhang, Hong <hzhang at mcs.anl.gov>
> *Sent:* Saturday, April 25, 2020 2:40 PM
> *To:* Pierre Jolivet <pierre.jolivet at enseeiht.fr>
> *Cc:* Jose E. Roman <jroman at dsic.upv.es>; Stefano Zampini <
> stefano.zampini at gmail.com>; petsc-dev <petsc-dev at mcs.anl.gov>; Smith,
> Barry F. <bsmith at mcs.anl.gov>
> *Subject:* Re: [petsc-dev] MATOP_MAT_MULT
> Pierre,
> When we do
> MatProductCreate: C = A*B; //C owns A and B, thus B->refct =2
> MatProductCreateWithMats: B = A*C; //If I let B own A and C, then
> C->refct=2
> Then
> MatDestroy(&B) and MatDestroy(&C) only reduce their refct from 2 to 1,
> thus memory leak.
> My solution is adding
> matreference; /* do not add refct when using
> MatProductCreateWithMat() to void recursive references */
> } Mat_Product
> This flg prevents MatProductCreateWithMats() to increase reference
> counts, i.e., B does not own A and C to avoid reverse ownership. I am not
> sure this is a reasonable solution. Let me know if you have better solution.
> See ex109.c and ex195.c for tests.
> Hong
> *From:* Pierre Jolivet <pierre.jolivet at enseeiht.fr>
> *Sent:* Saturday, April 25, 2020 11:45 AM
> *To:* Zhang, Hong <hzhang at mcs.anl.gov>
> Hong,
> José didn’t report this, though he may have run into the same issue, I did.
> I’ll try the branch and get back at you on GitLab MR.
> Thanks,
> Pierre
> On 25 Apr 2020, at 6:17 PM, Zhang, Hong <hzhang at mcs.anl.gov> wrote:
> Jose,
> >> I also now just tested some previously PETSC_VERSION_LT(3,13,0) running
> code with C=A*B, Dense=Nest*Dense, all previously allocated prior to a call
> to MatMatMult and scall = MAT_REUSE_MATRIX.
> >> Sadly, it’s now broken. It is my fault for not having a test for this in
> https://gitlab.com/petsc/petsc/-/merge_requests/2069, sorry about that.
> >> [0]PETSC ERROR: Call MatProductSymbolic() first
> >> [0]PETSC ERROR: #1 MatProductNumeric() line 730 in
> /ccc/work/cont003/rndm/rndm/petsc/src/mat/interface/matproduct.c
> >> [0]PETSC ERROR: #2 MatMatMult() line 9335 in
> /ccc/work/cont003/rndm/rndm/petsc/src/mat/interface/matrix.c
> >> Here is a reproducer (that will work OK with 3.12.4).
> >> diff --git a/src/mat/tests/ex195.c b/src/mat/tests/ex195.c
> >> index c72662bc3c..811de669c5 100644
> >> --- a/src/mat/tests/ex195.c
> >> +++ b/src/mat/tests/ex195.c
> >> @@ -73,2 +73,3 @@ int main(int argc,char **args)
> >> ierr =
> MatMatMult(nest,B,MAT_REUSE_MATRIX,PETSC_DEFAULT,&C);CHKERRQ(ierr);
> >> + ierr =
> MatMatMult(nest,C,MAT_REUSE_MATRIX,PETSC_DEFAULT,&B);CHKERRQ(ierr);
> >> ierr = MatMatMultEqual(nest,B,C,10,&equal);CHKERRQ(ierr);
> >> $ make -f gmakefile test searchin=mat_tests-ex195
> >> I believe this is very close to the topic at hand and issue #608, so
> maybe you could fix this as well in the same upcoming MR? Just let me know,
> I can have a crack it otherwise.
> This is a bug. I fixed it in the branch hzhang/fix-matproduct-reuse/maint.
> Can you test it?
> Hong
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200506/188cea2d/attachment-0001.html>
