[petsc-dev] Suggestions for MatProductCreate()
    Lisandro Dalcin
    dalcinl at gmail.com
    Fri Mar 27 12:49:15 CDT 2020
On Fri, 27 Mar 2020 at 05:09, hong at aspiritech.org <hong at aspiritech.org>
wrote:
> Lisandro,
>> As I said in previous emails, I'm not complaining about the API, I said
>> it was a welcome adition. All I'm asking is:
>> 1)  Fix the handling of reference counting. This is an implementation
>> detail, not really an API change.
> I'm creating a branch from master and patch it with your suggestions on
> reference counting.
OK, thanks!
>> 2) Add a simple new routine to the API, MatProductReset(D)  [or maybe
>> name it MatProductClear(D) ], that should throw away all of the D->product
>> stuff to release memory related to the product algorithm implementation.
>> After calling MatProductReset(D), you cannot call anymore
>> MatProductNumeric().
> Do you mean adding a public function MatProductClear(D) to clear internal
> data structure 'product' attached to D?
> For example, after destroy A and B, user should call  MatProductClear(D),
> i.e.,
> MatDestroy(&A) ;
> MatDestroy(&B) ;
> MatProductClear(D); // throw away all of the D->product stuff, thus D
> becomes a standard matrix
Exactly. MatProductClear(D) should make D a standard matrix and discard all
of the internal product stuff.
> I understand that you are concerned about the dangling pointers. However,
> most users compute D =A*B, then destroy A, B and D separately in random
> order. Do we require user to call MatProductClear(D) after A or B is
> destroyed?
No, MatProductClear() should not be required. I would
code MatProductClear(D) to be a non-op if D does not have the internal
product stuff. Then I would always call MatProductClear(D) in
MatDestroy(&D) .
Of course, all that assuming that MatProductCreate() makes D take ownership
(increment refcount) of A and B (and C if given). This way it does not
really matter the order in which users destroy A,B, and D.
As I said before, look at PCReset() and PCDestroy(). MatProcuctClear()
should work similarly as the Reset() routine.
>>> 3) For MatProduct, I consider
>>> MatProductSetFromOptions() is logically equivalent to
>>> MatSetFromOptions(),
>>> MatProductSymbolic() is logically equivalent to MatSetUp(),
>>> and
>>> MatProductNumeric() assembles the matproduct  D repeatedly when A or B
>>> are updated.
>> OK, so... your point it that what looks like "setup" code
>> in MatProductSetFromOptions() is just some minimal stuff required to
>> actually dispatch the SetFromOptions_typeA_typeB routine, right? In that
>> case, you are right, no changes/refactors needed here.
> Yes,  MatProductSetFromOptions() only
> dispatches SetFromOptions_typeA_typeB_producttype() which handles local
> options and polymorphism. The organization of new API is described at the
> top of petsc/src/mat/interface/matproduct.c.
OK, all good with that one.
Lisandro Dalcin
Research Scientist
Extreme Computing Research Center (ECRC)
King Abdullah University of Science and Technology (KAUST)
http://ecrc.kaust.edu.sa/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200327/10dd3bed/attachment.html>
