[petsc-dev] [petsc-users] About the interpolation and restriction matrix for cell-centered multigrid.
    Patrick Sanan
    patrick.sanan at gmail.com
    Tue Mar 24 10:57:14 CDT 2020
This sort of feedback is great in terms of learning what can move out of
"tutorials" and into "tests".
https://gitlab.com/petsc/petsc/-/merge_requests/2629
Am Di., 24. März 2020 um 16:22 Uhr schrieb Jed Brown <jed at jedbrown.org>:
> Mark Adams <mfadams at lbl.gov> writes:
> > Good question. It does look like there is Q1:
> > src/dm/impls/da/da.c:-  ctype - DMDA_Q1 and DMDA_Q0 are currently the
> only
> > supported forms
> > And in looking at a cell centered
> > example src/snes/examples/tutorials/ex20.c, it looks like only DMDA_Q1
> > works. I get an error when I set it to DMDA_Q0 (DMDA_Q1 is the default).
> > This is puzzling, Q0 is natural in cell centered.
> The comments in those examples are kinda wrong -- they never told the DM
> it was cell-centered so it uses a multigrid that isn't compatible with
> the boundary conditions.  The interpolation is Q1 on the dual grid, not
> conservative Q1 on cells.
> > I am not familiar with DMDA and I don't understand why, from ex20, that
> you
> > have an odd number of points on a cell centered grid and an even number
> for
> > vertex centered (eg, ex14). I would think that it should be the opposite.
> The example is bad.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200324/55073c06/attachment-0001.html>
