[petsc-dev] Suggestions for MatProductCreate()
Lisandro Dalcin
dalcinl at gmail.com
Sun Mar 22 17:56:49 CDT 2020
MatProductSetFromOptions() is not really setting any options. It looks like
the correct name for this API is MatProductSetUp(). In any case, it looks
like both SetFromOptions() and SetUp() should be provided.
On Mon, 23 Mar 2020 at 01:48, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> * Please consider fixing MatProductCreate(A,B,C,&D) to take ownership
> (that is, increase reference count) of the A,B, and the (optional) C
> matrices provided as arguments. Otherwise it is way easy to get into the
> dangling pointer trap.
> * A thing also missing in the new API is a way to "cleanup" the A,B,C
> references, something MatProductReset(D) to get rid of (deallocates) the
> internal "product" context, thus removing from D the references to A,B,C.
> This would be useful if you just want to compute JUST the symbolic product,
> I'm using that in some code to compute the nonzero pattern of A^2.
> * It should be also considered to provide backward compatibility
> PETSC_DEPRECATED calls to the previous MatMatMultSymbolic()
> and MatMatMultNumeric(). It looks like it would be trivial to do, though I
> may be getting it wrong because I have not looked at all the details.
> Regards,
> Lisandro Dalcin
> Research Scientist
> Extreme Computing Research Center (ECRC)
> King Abdullah University of Science and Technology (KAUST)
> http://ecrc.kaust.edu.sa/
Lisandro Dalcin
Research Scientist
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200323/9ffa073c/attachment-0001.html>
