[petsc-dev] Multiple MPICH/fblaslapack Installs For Multiple Arches
    Satish Balay
    balay at mcs.anl.gov
    Sun Mar 22 16:33:32 CDT 2020
As Jed mentioned - I use system blaslapack on linux/ Mac [no need for --download-fblaslapack] on these. And then I have a single install of MPICH in my PATH that I use for all my builds.
You can get this with:
./configure --prefix=$HOME/soft/mpich-3.3.2 CFLAGS= COPTFLAGS= FFLAGS= FOPTFLAGS= CXXFLAGS= CXXOPTFLAGS=
[and then add $HOME/soft/mpich-3.3.2/bin in PATH]
I use ccache differently - not wrap MPI wrappers - but just gcc/g++
$ which gcc
/usr/lib64/ccache/gcc
If using in-pace install then PETSc configure does not rebuild packages unless the configure options to build that package has changed [or if its installed from git - gitcommit has changed]
And its best not to change options to configure - when reusing PETSC_ARCH [however - changes within configure can change some of the default compiler flags or package options - that can result in a rebuild]
Satish
On Sun, 22 Mar 2020, Jacob Faibussowitsch wrote:
> > Do you mean 32-bit/64-bit (pointers) or --with-64-bit-indices=0/1 ? [or do you have --known-64-bit-blas-indices in the mix?]
> Sorry, I mean configuring petsc with —with-64-bit-indices=1 here.
> Best regards,
> (Jacob Fai - booss - oh - vitch)
> Cell: (312) 694-3391
> > Satish
> >> Hello all,
> >> As part of development, I have several arch folders lying around in my PETSC_DIR namely a 32-bit OSX, 64-bit OSX, 32-bit linux with valgrind, 64-bit linux with valgrind, and a 32-bit up to date with current master. All of these have a —download-mpich —download-fblaslapack and hence their own copy of each (so that’s 5 copies of each, plus other duplicated packages im sure). At this stage, even getting the bare minimum of these arches ready for dev work after a rebase/git pull takes decades as package versions, or conf settings change, forcing a rebuild of the same packages multiple times.
> >> My question(s):
> >> What petsc ./configure options are necessary to change the configuration of each library w.r.t. petsc? i.e. can my 64-bit arches use my 32-bit MPICH/fblaslapack and vice-versa? Does this change when I have —with-debug on or off? If so, what other packages have a similar ability? Is there anywhere in ./configure —help where this kind of information would be documented?
> >> I suspect that this hasn’t been fully explored since its primarily a developer “problem” and not one the average user will run into/care about (since they usually aren’t building petsc multiple times). I’m sure everyone has their own ways of tackling this problem, I’d love to hear them.
> >> Best regards,
