[petsc-dev] print statements in fortran interface functions
Mark Adams
mfadams at lbl.gov
Mon Mar 16 19:54:17 CDT 2020
I am trying to debug an application code that works with v3.7 but fails
with master. The code works for "normal" solvers but for a solver that uses
FieldSplit it fails. It looks like vectors are not getting created from
MatCreateVecs with a matrix that is a MatNest (I can't run the code).
I have put print statements in the interface files to try to see what is
going on but the print statements seem to disappear somehow. (I added the
same print statements in my installation of v3.7 to see what is different)
I was using PetscPrint and then found and example of a Fortran PetscInfo
and switched to that. I stepped through the code with DDT and see the print
statements but nothing goes to the output. I did this DDT stuff with
ex73f90t, which has a MatCreateNest.
I am completely baffled. Does anyone have any ideas?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200316/6704f147/attachment.html>
