[petsc-dev] Request for comments: allow C99 internally
Jed Brown
jed at jedbrown.org
Wed Mar 11 10:34:31 CDT 2020
My proposal is for PETSc to support the intersection of C99, C11, C++11,
and any later standards. This (sadly*) excludes VLA.
[*] I don't care about stack allocation, but VLA-pointers are extremely
useful for multi-dimensional array indexing. I'm sad that C11 made that
optional.
Jeff Hammond <jeff.science at gmail.com> writes:
> I wonder if it is not more useful to talk in terms of C11 features. Unlike
> C99, C11 makes VLAs optional via __STDC_NO_VLA__, so you have a
> standardized way of expressing the subset of C11 that is compatible with
> C++11. __STDC_NO_ATOMICS__ and __STDC_NO_THREADS__ play a similar role.
> Of course, some compilers refuse to use these properly, so PETSc will have
> to check compiler support directly rather than trusting macros, but that is
> nothing new and Jed (rightly) doesn't trust such compiler macros anyways.
> I merely suggest that the macros correspond to an ISO C language definition
> for describing the portable subset in a way that C99 cannot.
I don't think the macros are of any utility in defining the
intersection. For example, g++ and clang++ do not set __STDC_NO_VLA__
(and aren't expected to because they aren't C compilers), yet they don't
support the syntax.
double (*a)[n] = (double (*)[n])p;
a[i][j] = 42;
