[petsc-dev] Request for comments: allow C99 internally
Patrick Sanan
patrick.sanan at gmail.com
Sat Mar 7 06:11:01 CST 2020
Perhaps naively, I‘d assume that while there may well be someone out there
relying on compilers for which this would be a problem, that same person is
also less likely to be able to upgrade PETSc.
The benefits seem well worth it. It‘ll make things just that much easier to
work with.
+1 for the for-loop declarations.
No more need to police the use of // C++-style comments?
Jed Brown <jed at jedbrown.org> schrieb am Sa. 7. März 2020 um 06:48:
> I have a question for petsc-dev: Do you know anyone who needs to build
> PETSc with a compiler that doesn't support variadic macros and for-loop
> declarations? (Both of these are in C99 and C++11, and supported by all
> tested configurations including compilers that don't fully implement
> these standards.) Both MPICH and Open MPI use variable-length arrays
> and for-loop declarations, so you'd be hard-pressed building a modern
> stack with such a compiler. I'm not proposing that we put these macros
> unguarded into the public headers, so a user of PETSc could still build
> with -std=c89 and the like.
> ## Background
> There is a common pattern in PETSc where we write
> PetscInt some,several,variables;
> // code
> #if defined(PETSC_HAVE_MAGIC)
> function(several,&variables);
> #endif
> use(some,variables);
> Of course this gives unused variable warnings, so we tear our code apart
> like
> PetscInt some,variables;
> PetscInt several;
> #endif
> // code
> #endif
> but the bigger problem is that we need different configurations just to
> check syntax of our compiled out blocks. I propose allowing variadic
> macros (a C99 and C++11 feature) to allow code like
> // code
> if (PetscDefined(HAVE_MAGIC)) {
> This approach could also be used to avoid needing separate macros for
> every SETERRQ1-SETERRQ9, etc. I have an example implementation in this
> MR, and it passes the full pipeline (after relaxing the -std=c89
> -pedantic build).
> https://gitlab.com/petsc/petsc/-/merge_requests/157/diffs
> We could also consider allowing for-loop declarations, which I believe
> leads to tighter and more understandable code because the reader doesn't
> have to wonder whether the variable is used after the loop.
> for (PetscInt i=0; i<n; i++) { ... }
> Note that we cannot use variable-length arrays (VLA) because they are
> not in the intersection of C and C++.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200307/59261792/attachment.html>
