[petsc-dev] Getting .gitlab.ci file out of repository? https://docs.gitlab.com/ee/ci/pipelines/settings.html
    Satish Balay
    balay at mcs.anl.gov
    Tue Jun 23 10:26:54 CDT 2020
On Tue, 23 Jun 2020, Satish Balay via petsc-dev wrote:
> One way to do this is with redundancy [of machines - where same test would work on either machine] - which we don't have for all OSes..
Just wanted to add - this was not easy to do even with linux or OSX.. [Windows is a different beast :(]
With linux:
-  difference in hardware versions [different gen Intel CPUs] cause PGI test failures [when reusing petsc-hash-packages built on a slightly different version]
- slight difference in software stack [- even with the same OS/version] causes gcov failures [when reusing petsc-hash-packages built on a slightly different version]
With OSX - For some reason Apple decides to have slightly different version of compilers on each of the boxes - even though I run updates at the same time..
balay at sb /home/balay/tmp
$ ssh ipro clang --version
Apple clang version 11.0.3 (clang-1103.0.32.62)
Target: x86_64-apple-darwin19.5.0
Thread model: posix
InstalledDir: /Library/Developer/CommandLineTools/usr/bin
$ ssh jpro clang --version
Thread model: posix
InstalledDir: /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin
$ ssh kpro clang --version
Apple clang version 11.0.0 (clang-1100.0.33.8)
Thread model: posix
And some (opt) test failed (or gave different results?) on of these boxes (jpro).  The other one gets random <U+0000> errors (kpro)
So i have some these tests bound to a machine instead of having them float between equivalent machines..
I guess things can be improved by somehow deploying the exact same hardware, software etc, but then this reduces some of the test coverage.. [for ex: removing various linux OS variants - and using a single  one]
Different trade-offs that are already represented in current .gitlab-ci.yaml.
Satish
