[petsc-dev] bash scripts to make PETSc development easier, less recompiles, less cut and pastes
Jed Brown
jed at jedbrown.org
Thu Jun 18 21:33:01 CDT 2020
Barry Smith <bsmith at petsc.dev> writes:
> Nice, I didn't know about that alternative, I'll check it out.
AFAIK, there is still no push option to run a pipeline. There's an
option ci.skip if you're configured to run by default. If developers
set ci.skip as a default push option, we could re-enable the default
case.
>> On Jun 18, 2020, at 9:21 PM, Jed Brown <jed at jedbrown.org> wrote:
>> Cool! Note that you can do things like this without going through the API
>> git push -o merge_request.create -o merge_request.target=maint
