[petsc-dev] Valgrind MPI-Related Errors
Jacob Faibussowitsch
jacob.fai at gmail.com
Tue Jun 2 12:11:15 CDT 2020
> You can verify with: mpichversion
Yes you’re right. Here is what this produces for me
MPICH Version: 3.3.2
MPICH Release date: Tue Nov 12 21:23:16 CST 2019
MPICH Device: ch3:sock
MPICH configure: --disable-wrapper-rpath --with-device=ch3:sock
MPICH CC: gcc -O2
MPICH CXX: g++ -O2
MPICH F77: gfortran -O2
MPICH FC: gfortran -O2
MPICH Custom Information:
Best regards,
(Jacob Fai - booss - oh - vitch)
Cell: (312) 694-3391
> On Jun 2, 2020, at 11:59 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> MPICH need to be built with the option --enable-g=meminit for it to be valgrind clean.
> --download-mpich does this [among other things that are useful during software developement]. Pre-configured MPICH is not likely to do this.
> You can prebuild MPICH using PETSc with:
> ./configure --prefix=$HOME/soft/mpich --download-mpich CFLAGS= FFLAGS= CXXFLAGS= COPTFLAGS= CXXOPTFLAGS= FOPTFLAGS=
> And make this your default pre-installed MPI. [by adding $HOME/soft/mpich to PATH]
> Satish
> On Tue, 2 Jun 2020, Jacob Faibussowitsch wrote:
>> Yes I am using the pre-loaded MPICH from the docker image. Further proof from configure
>> #define PETSC_HAVE_MPICH_NUMVERSION 30302300
>> #define PETSC_HAVE_MPIEXEC_ENVIRONMENTAL_VARIABLE MPIR_CVAR_CH3
>> Best regards,
>>> On Jun 2, 2020, at 11:35 AM, Junchao Zhang <junchao.zhang at gmail.com> wrote:
>>> I guess Jacob already used MPICH, since MPIDI_CH3_EagerContigShortSend() is from MPICH.
>>> --Junchao Zhang
>>> On Tue, Jun 2, 2020 at 9:38 AM Satish Balay via petsc-dev <petsc-dev at mcs.anl.gov <mailto:petsc-dev at mcs.anl.gov> <mailto:petsc-dev at mcs.anl.gov <mailto:petsc-dev at mcs.anl.gov>>> wrote:
>>> use --download-mpich for valgrind.
>>> https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind <https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind><https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind <https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind>>
>>> Satish
>>> On Tue, 2 Jun 2020, Karl Rupp wrote:
>>>> Hi Jacob,
>>>> the recommendation in the past was to use MPICH as it is (was?)
>>>> valgrind-clean. Which MPI do you use? OpenMPI used to have these kinds of
>>>> issues. (My information might be outdated)
>>>> Best regards,
>>>> Karli
>>>> On 6/2/20 2:43 AM, Jacob Faibussowitsch wrote:
>>>>> Hello All,
>>>>> TL;DR: valgrind always complains about "Syscall param write(buf) points to
>>>>> uninitialised byte(s)” for a LOT of MPI operations in petsc code, making
>>>>> debugging using valgrind fairly annoying since I have to sort through a ton
>>>>> of unrelated stuff. I have built valgrind from source, used apt install
>>>>> valgrind, apt install valgrind-mpi to no avail.
>>>>> I am using valgrind from docker. Dockerfile is attached below as well. I
>>>>> have been unsuccessfully trying to resolve these local valgrind errors, but
>>>>> I am running out of ideas. Googling the issue has also not provided entirely
>>>>> applicable solutions. Here is an example of the error:
>>>>> $ make -f gmakefile test VALGRIND=1
>>>>> #==54610== Syscall param write(buf) points to uninitialised byte(s)
>>>>> #==54610== at 0x6F63317: write (write.c:26)
>>>>> #==54610== by 0x9056AC9: MPIDI_CH3I_Sock_write (in
>>>>> /usr/local/lib/libmpi.so.12.1.8)
>>>>> #==54610== by 0x9059FCD: MPIDI_CH3_iStartMsg (in
>>>>> #==54610== by 0x903F298: MPIDI_CH3_EagerContigShortSend (in
>>>>> #==54610== by 0x9049479: MPID_Send (in /usr/local/lib/libmpi.so.12.1.8)
>>>>> #==54610== by 0x8FC9B2A: MPIC_Send (in /usr/local/lib/libmpi.so.12.1.8)
>>>>> #==54610== by 0x8F86F2E: MPIR_Bcast_intra_binomial (in
>>>>> #==54610== by 0x8EE204E: MPIR_Bcast_intra_auto (in
>>>>> #==54610== by 0x8EE21F4: MPIR_Bcast_impl (in
>>>>> #==54610== by 0x8F887FB: MPIR_Bcast_intra_smp (in
>>>>> #==54610== by 0x8EE206E: MPIR_Bcast_intra_auto (in
>>>>> #==54610== by 0x8EE2A6F: PMPI_Bcast (in /usr/local/lib/libmpi.so.12.1.8)
>>>>> #==54610== by 0x4B377B8: PetscOptionsInsertFile (options.c:525)
>>>>> #==54610== by 0x4B39291: PetscOptionsInsert (options.c:672)
>>>>> #==54610== by 0x4B5B1EF: PetscInitialize (pinit.c:996)
>>>>> #==54610== by 0x10A6BA: main (ex9.c:75)
>>>>> #==54610== Address 0x1ffeffa944 is on thread 1's stack
>>>>> #==54610== in frame #3, created by MPIDI_CH3_EagerContigShortSend (???:)
>>>>> #==54610== Uninitialised value was created by a stack allocation
>>>>> #==54610== at 0x903F200: MPIDI_CH3_EagerContigShortSend (in
>>>>> There are probably 20 such errors every single time, regardless of what code
>>>>> is being run. I have tried using apt install valgrind, apt install
>>>>> valgrind-mpi, and building valgrind from source:
>>>>> # VALGRIND
>>>>> WORKDIR /
>>>>> RUN git clone git://sourceware.org/git/valgrind.git <git://sourceware.org/git/valgrind.git> <http://sourceware.org/git/valgrind.git <http://sourceware.org/git/valgrind.git>>
>>>>> WORKDIR /valgrind
>>>>> RUN git pull
>>>>> RUN ./autogen.sh
>>>>> RUN ./configure --with-mpicc=/usr/local/bin/mpicc
>>>>> RUN make -j 5
>>>>> RUN make install
>>>>> None of the those approaches lead to these errors disappearing. Perhaps I am
>>>>> missing some funky MPI args?
>>>>> Best regards,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200602/8250ad52/attachment.html>
