[petsc-dev] Valgrind MPI-Related Errors
Jacob Faibussowitsch
jacob.fai at gmail.com
Tue Jun 2 11:43:34 CDT 2020
Yes I am using the pre-loaded MPICH from the docker image. Further proof from configure
#define PETSC_HAVE_MPICH_NUMVERSION 30302300
#define PETSC_HAVE_MPIEXEC_ENVIRONMENTAL_VARIABLE MPIR_CVAR_CH3
Best regards,
(Jacob Fai - booss - oh - vitch)
Cell: (312) 694-3391
> On Jun 2, 2020, at 11:35 AM, Junchao Zhang <junchao.zhang at gmail.com> wrote:
> I guess Jacob already used MPICH, since MPIDI_CH3_EagerContigShortSend() is from MPICH.
> --Junchao Zhang
> On Tue, Jun 2, 2020 at 9:38 AM Satish Balay via petsc-dev <petsc-dev at mcs.anl.gov <mailto:petsc-dev at mcs.anl.gov>> wrote:
> use --download-mpich for valgrind.
> https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind <https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind>
> Satish
> On Tue, 2 Jun 2020, Karl Rupp wrote:
> > Hi Jacob,
> > the recommendation in the past was to use MPICH as it is (was?)
> > valgrind-clean. Which MPI do you use? OpenMPI used to have these kinds of
> > issues. (My information might be outdated)
> > Best regards,
> > Karli
> > On 6/2/20 2:43 AM, Jacob Faibussowitsch wrote:
> > > Hello All,
> > > TL;DR: valgrind always complains about "Syscall param write(buf) points to
> > > uninitialised byte(s)” for a LOT of MPI operations in petsc code, making
> > > debugging using valgrind fairly annoying since I have to sort through a ton
> > > of unrelated stuff. I have built valgrind from source, used apt install
> > > valgrind, apt install valgrind-mpi to no avail.
> > > I am using valgrind from docker. Dockerfile is attached below as well. I
> > > have been unsuccessfully trying to resolve these local valgrind errors, but
> > > I am running out of ideas. Googling the issue has also not provided entirely
> > > applicable solutions. Here is an example of the error:
> > > $ make -f gmakefile test VALGRIND=1
> > > #==54610== Syscall param write(buf) points to uninitialised byte(s)
> > > #==54610== at 0x6F63317: write (write.c:26)
> > > #==54610== by 0x9056AC9: MPIDI_CH3I_Sock_write (in
> > > /usr/local/lib/libmpi.so.12.1.8)
> > > #==54610== by 0x9059FCD: MPIDI_CH3_iStartMsg (in
> > > #==54610== by 0x903F298: MPIDI_CH3_EagerContigShortSend (in
> > > #==54610== by 0x9049479: MPID_Send (in /usr/local/lib/libmpi.so.12.1.8)
> > > #==54610== by 0x8FC9B2A: MPIC_Send (in /usr/local/lib/libmpi.so.12.1.8)
> > > #==54610== by 0x8F86F2E: MPIR_Bcast_intra_binomial (in
> > > #==54610== by 0x8EE204E: MPIR_Bcast_intra_auto (in
> > > #==54610== by 0x8EE21F4: MPIR_Bcast_impl (in
> > > #==54610== by 0x8F887FB: MPIR_Bcast_intra_smp (in
> > > #==54610== by 0x8EE206E: MPIR_Bcast_intra_auto (in
> > > #==54610== by 0x8EE2A6F: PMPI_Bcast (in /usr/local/lib/libmpi.so.12.1.8)
> > > #==54610== by 0x4B377B8: PetscOptionsInsertFile (options.c:525)
> > > #==54610== by 0x4B39291: PetscOptionsInsert (options.c:672)
> > > #==54610== by 0x4B5B1EF: PetscInitialize (pinit.c:996)
> > > #==54610== by 0x10A6BA: main (ex9.c:75)
> > > #==54610== Address 0x1ffeffa944 is on thread 1's stack
> > > #==54610== in frame #3, created by MPIDI_CH3_EagerContigShortSend (???:)
> > > #==54610== Uninitialised value was created by a stack allocation
> > > #==54610== at 0x903F200: MPIDI_CH3_EagerContigShortSend (in
> > > There are probably 20 such errors every single time, regardless of what code
> > > is being run. I have tried using apt install valgrind, apt install
> > > valgrind-mpi, and building valgrind from source:
> > > # VALGRIND
> > > WORKDIR /
> > > RUN git clone git://sourceware.org/git/valgrind.git <http://sourceware.org/git/valgrind.git>
> > > WORKDIR /valgrind
> > > RUN git pull
> > > RUN ./autogen.sh
> > > RUN ./configure --with-mpicc=/usr/local/bin/mpicc
> > > RUN make -j 5
> > > RUN make install
> > > None of the those approaches lead to these errors disappearing. Perhaps I am
> > > missing some funky MPI args?
> > > Best regards,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200602/f8f7c244/attachment.html>
