[petsc-dev] why does the Ubuntu PETSc package install coarray Fortran?
Jeff Hammond
jeff.science at gmail.com
Mon Jun 1 13:57:31 CDT 2020
Thanks everybody for your help. I'll use this in the future, but for now,
building from source with minimal features is working for me.
Jeff
On Sun, May 31, 2020 at 9:06 PM Drew Parsons <dparsons at debian.org> wrote:
> On 2020-06-01 10:48, Satish Balay wrote:
> > This is likely a dependency of a dependency.
> > In rpm world - you can do something like:
> > [root at sb ~]# repoquery --whatrequires SuperLU.x86_64
> > Last metadata expiration check: 0:07:55 ago on Sun 31 May 2020 09:38:39
> > PM CDT.
> > SuperLU-devel-0:5.2.1-8.fc32.x86_64
> > SuperLU-doc-0:5.2.1-8.fc32.x86_64
> > armadillo-0:9.860.1-1.fc32.x86_64
> > armadillo-0:9.880.1-1.fc32.x86_64
> > freefem++-0:4.4.2-2.fc32.x86_64
> > freefem++-0:4.6-1.fc32.x86_64
> > hypre-0:2.18.1-2.fc32.x86_64
> > mld2p4-serial-0:2.2.1-5.fc32.x86_64
> > octave-iso2mesh-0:1.9.1-5.fc32.x86_64
> > petsc-0:3.12.3-2.fc32.x86_64
> > I don't know what the equivalent in deb world is.
> > So I would manually check on some of the petsc dependencies
> > apt install libblas-dev
> > apt install libsuitesparse-dev
> > etc..
> > cc: Drew, perhaps has a better answer.
> > Satish
> > On Sun, 31 May 2020, Jeff Hammond wrote:
> >> I understand a lot of these but how does PETSc depend on OpenCoarrays?
> >> Obviously, I do not fault the PETSc developers for this, because I
> >> know
> >> they are not using coarray Fortran, but maybe somebody on this list
> >> knows
> >> who is creating the Ubuntu packages for PETSc.
> >> If there is a simple way to understand this using Apt, please share.
> >> I ran
> >> apt-rdepend but do not see any reference to the coarrays stuff, so I
> >> don't
> >> know how it is getting included here.
> >> Jeff
> >> $ sudo apt-get install petsc-dev
> >> [sudo] password for jrhammon:
> >> Reading package lists... Done
> >> Building dependency tree
> >> Reading state information... Done
> >> The following additional packages will be installed:
> >> ksh libaec-dev libaec0 libamd2 libblas-dev libbtf1 *libcaf-openmpi-3
> >> *libcamd2
> >> libccolamd2 libcholmod3 *libcoarrays-openmpi-dev* libcolamd2
> tl;dr: "apt-cache rdepends", "apt-rdepends -r"
> Needed library dependencies get embedded in the shared libraries and can
> be read with objdump,
> $objdump -p
> /usr/lib/petscdir/petsc3.12/x86_64-linux-gnu-real/lib/libpetsc_real.so.3.12.4
> But you're asking at package level for the reverse dependencies of a
> package, which other packages depend on a given package. There are a
> couple of tools for that.
> apt-cache from the apt package is short and simple, using the rdepends
> action
> $ apt-cache rdepends libcoarrays-openmpi-dev libcamd2 libcaf-openmpi-3
> Reverse Depends:
> libopenmpi-dev
> libcamd2
> Reverse Depends:
> libsuitesparse-dev
> libcholmod3
> libcaf-openmpi-3
> Reverse Depends:
> "apt-cache show <pkg>" prints the description for the package, including
> its Dependencies. Handy for double-checking that rdepends is giving you
> reverse-dependencies, not dependencies (it's easy to forget if you're
> looking forwards or backwards).
> apt-rdepends (in the apt-rdepends package) gives the whole chain right
> to the end, possibly Too Much Information. Despite the name,
> "apt-rdepends libcamd2" actually gives forward dependencies (what
> libcamd2 depends on) (in apt-rdepends it's r for recursive, not
> reverse). To find the chain of reverse dependencies in the opposite
> direction, use "apt-rdepends -r libcamd2".
> "apt-rdepend -b" generates the list of build-dependencies that the
> package needs to build it (sadly "apt-rdepends -b -r" does not work, so
> it's less straightforward to know which other packages use it as a
> Reverse-Dependency)
> apt-rdepends and apt-cache might miss some references (e.g. Suggests
> rather than Depends). This search from Rebecca Palmer can be useful for
> those cases
> pkg=libcamd2; grep-dctrl -w -F Pre-Depends,Depends,Recommends,Suggests
> -s Source "$pkg"
> /var/lib/apt/lists/*_debian_dists_unstable_main_binary-amd64_Packages ;
> grep-dctrl -w -s Package "$pkg"
> /var/lib/apt/lists/*_debian_dists_unstable_main_source_Sources
> "apt-rdepends -r" libcamd2 tells us the chain is petsc - libcholmod3 -
> libcamd2
> libcaf-openmpi-3 is needed by libcoarrays-openmpi-dev
> libcoarrays-openmpi-dev is not a dependency for any package. It might be
> a build dependency for something, or possibly it's simply not used yet.
> Just an OpenMPI tool available for use.
> In short, libcholmod3 from suitesparse uses libcamd2.
Jeff Hammond
http://jeffhammond.github.io/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200601/8a025255/attachment.html>
