[petsc-dev] Question about MPICH device we use
Satish Balay
balay at mcs.anl.gov
Thu Jul 23 23:33:26 CDT 2020
The primary reason is for users - developing on laptops/desktop and doing development runs in oversubscribed mode.
The choice was few percent loss in performance for sock vs exponential cost for oversubscribed usage of nemesis [so we defaulted to sock].
I think we should preserve this behavior for at-least the debug builds. [i.e switch only optimized builds to nemesis]
In CI we do pay this extra cost for some of the builds [that explicitly test with wemesis, openmpi etc..]
Satish
On Thu, 23 Jul 2020, Jed Brown wrote:
> I think we should default to ch3:nemesis when --download-mpich, and only do ch3:sock when requested (which we would do in CI).
> Satish Balay via petsc-dev <petsc-dev at mcs.anl.gov> writes:
> > Primarily because ch3:sock performance does not degrade in oversubscribe mode - which is developer friendly - i.e on your laptop.
> > And folks doing optimized runs should use a properly tuned MPI for their setup anyway.
> > In this case --download-mpich-device=ch3:nemesis is likely appropriate if using --download-mpich [and not using a separate/optimized MPI]
> > Having defaults that satisfy all use cases is not practical.
> > Satish
> > On Wed, 22 Jul 2020, Matthew Knepley wrote:
> >> We default to ch3:sock. Scott MacLachlan just had a long thread on the
> >> Firedrake list where it ended up that reconfiguring using ch3:nemesis had a
> >> 2x performance boost on his 16-core proc, and noticeable effect on the 4
> >> core speedup.
> >> Why do we default to sock?
> >> Thanks,
> >> Matt
