[petsc-dev] Question about MPICH device we use
Jed Brown jed at jedbrown.org
Thu Jul 23 14:40:38 CDT 2020
I think we should default to ch3:nemesis when --download-mpich, and only do ch3:sock when requested (which we would do in CI).
Satish Balay via petsc-dev <petsc-dev at mcs.anl.gov> writes:
> Primarily because ch3:sock performance does not degrade in oversubscribe mode - which is developer friendly - i.e on your laptop.
> And folks doing optimized runs should use a properly tuned MPI for their setup anyway.
> In this case --download-mpich-device=ch3:nemesis is likely appropriate if using --download-mpich [and not using a separate/optimized MPI]
> Having defaults that satisfy all use cases is not practical.
> Satish
> On Wed, 22 Jul 2020, Matthew Knepley wrote:
>> We default to ch3:sock. Scott MacLachlan just had a long thread on the
>> Firedrake list where it ended up that reconfiguring using ch3:nemesis had a
>> 2x performance boost on his 16-core proc, and noticeable effect on the 4
>> core speedup.
>> Why do we default to sock?
>>   Thanks,
>>      Matt
