[petsc-dev] gcc 10
Mark Adams mfadams at lbl.gov
Mon Jul 13 14:57:09 CDT 2020
yes,
On Mon, Jul 13, 2020 at 3:56 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Jul 13, 2020 at 3:55 PM Mark Adams <mfadams at lbl.gov> wrote:
>> It's been fixed and it's in my F90 test.
> Did you take out the -fallow_... ?
>   Matt
>> On Mon, Jul 13, 2020 at 3:54 PM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Mon, Jul 13, 2020 at 3:50 PM Mark Adams <mfadams at lbl.gov> wrote:
>>>> On Mon, Jul 13, 2020 at 1:40 PM Jed Brown <jed at jedbrown.org> wrote:
>>>>> I don't know what failure you're referring to.  The C++ complex thing
>>>>> might have been a matter of the antique compiler.
>>>> The failure was fixed with -fallow_ .... but it gave warnings.
>>> Mark, can you try Barry's fix, changing the declaration of
>>> PetscObjectSetName()?
>>>   Thanks,
>>>      Matt
>>>>> Matthew Knepley <knepley at gmail.com> writes:
>>>>> > Why did Mark have the gcc 10 failure on our example. Was it
>>>>> something with
>>>>> > did in it?
>>>>> >    Matt
>>>>> > On Mon, Jul 13, 2020 at 12:43 PM Jed Brown <jed at jedbrown.org> wrote:
>>>>> >> You want this for PETSc or for external packages?  We add it for a
>>>>> bunch
>>>>> >> of external packages.  I've been building PETSc with
>>>>> gcc/gfortran-10 for
>>>>> >> months now.
>>>>> >> > Do we have gfortran from gcc 10 running anywhere? We need a check
>>>>> to
>>>>> >> enable
>>>>> >> >   -fallow-argument-mismatch
>>>>> >> > from configure. Should be as simple as compiling Fortran which has
>>>>> >> > PetscObjectSetName() in it.
>>>>> >> >   Thanks,
>>>>> >> >       Matt
>>>>> >> > What most experimenters take for granted before they begin their
>>>>> >> > experiments is infinitely more interesting than any results to
>>>>> which
>>>>> >> their
>>>>> >> > experiments lead.
>>>>> >> > -- Norbert Wiener
>>>>> >> > https://www.cse.buffalo.edu/~knepley/ <
>>>>> >> http://www.cse.buffalo.edu/~knepley/>
>>>>> > experiments is infinitely more interesting than any results to which
>>>>> their
>>>>> > experiments lead.
>>>>> > -- Norbert Wiener
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200713/0e8ff36b/attachment-0001.html>
