[petsc-dev] gcc 10
Satish Balay
balay at mcs.anl.gov
Mon Jul 13 11:47:06 CDT 2020
Yeah - we fixed PETSc [maint] to not require -fallow-argument-mismatch - and use it only with externalpacakges that need it
And we do have one test box with gfortran-10 - but the test coverage with it is minimal. [mostly no externalpacakges]
Satish
On Mon, 13 Jul 2020, Jed Brown wrote:
> You want this for PETSc or for external packages? We add it for a bunch of external packages. I've been building PETSc with gcc/gfortran-10 for months now.
> Matthew Knepley <knepley at gmail.com> writes:
> > Do we have gfortran from gcc 10 running anywhere? We need a check to enable
> > from configure. Should be as simple as compiling Fortran which has
> > PetscObjectSetName() in it.
> > Thanks,
> > Matt
> > What most experimenters take for granted before they begin their
> > experiments is infinitely more interesting than any results to which their
> > experiments lead.
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
