[petsc-dev] Sphinx error
Jed Brown
jed at jedbrown.org
Mon Jul 6 23:01:55 CDT 2020
Barry Smith <bsmith at petsc.dev> writes:
> Apple introduced the concept of Framework for packaging long before
> Linux had half-way decent package managers.
Debian debuted in 1996 with hundreds of packages and sufficient package management to enable continuous upgrades through to the modern era (no reinstall; e.g., https://lwn.net/Articles/226110/).
You can blame Linux distros for lots of things, but reliable package management ain't one of them.
> And it is not bad, manages versions, packaging, all the stuff you
> need. But because it is slightly different than the traditional Unix
> approaches and the Apple world used to be much smaller in open
> source users the open source community never adopted it as the way
> to deliver packages on Apple, they instead built Linux like package
> manager clones and totally by-passed the Framework approach. I don't
> think you can blame Apple; they do have a reasonable packaging
> system, the open source community just doesn't use it. I use to
> build PETSc frameworks for Apple but doubt that a single person used
> them so I stopped.
>> On Jul 6, 2020, at 10:08 PM, Jed Brown <jed at jedbrown.org> wrote:
>> I don't envy the Brew developers who take the blame when Apple breaks things underneath them. I still boggle at the fact that the clear majority of people use operating systems that lack integrated package management. This problem has been solved for 25 years.
>>> My fault, for some reason sphinx from brew installed its own private python so I had to do the pip at that.
>>>>> Apple's python 2 doesn't use pip
>>>>> $ sudo easy_install src/docs/sphinx_docs/requirements.txt
>>>>> Processing requirements.txt
>>>>> error: Not a recognized archive type: src/docs/sphinx_docs/requirements.txt
>>>>> Is this thing supported only for python3?
>>>> Perhaps. Python2 is EOL. Try this
>>>> python3 -m pip install --user -r src/docs/sphinx_docs/requirements.txt
